• Hardware Platform (Jetson / GPU) : Jetson AGX Xavier
• DeepStream Version: 5.1
• JetPack Version (valid for Jetson only): 4.6
• Issue Type( questions, new requirements, bugs): Low Performance (FPS) between Deepstream + Triton architecture with Deepstream architecture only
• How to reproduce the issue ? ()
I make the performance TEST comparison between Deepstream + Triton architecture with Deepstream architecture only on Jetson AGX Xavier with the same video following these sample apps:
Deepstream + Triton: Following the instruction here, I run the sample app with this command:
deepstream-app -c source1_primary_detector.txt text
Deepstream only: I run the deepstream-test2 sample from here with command:
python3 deepstream_test_2.py /opt/nvidia/deepstream/deepstream-5.1/samples/streams/sample_720p.h264
The result shows that Deepstream only is faster than Deepstream + Triton. So my questions are:
- Is Deepstream only is faster than Deepstream + Triton ?
- If NOT, do I miss something in installations ?
You can see the video that I record. First is Deepstream + Triton from [00:00-01:19] , Second is the left.
Thank you very much!
