i acquired recently a SuperMicro server with 2 Tesla M60.
i could set up everything but once i started lunch VDI´s with 4GB or 8GB i always get the same error in the license server:
02:47:54,478 INFO Updated feature Quadro-Virtual-DWS 5.0 count=64
02:47:54,479 INFO Received one valid feature in license update
02:48:13,939 WARN Unable to handle request for feature GRID-Virtual-Apps 3.0 count=1. Reason: FEATURE_NOT_AVAILABLE.
as i understand, that the license server is up and running but somehow i could not use this profiles, if i shutdown the VDI and change the profile the license will be granted, otherwise no license for those profiles.
Every profile except M60-4Q, M60-8Q, M6-4Q, M6-8Q profiles works wonderfully.
Can you help me ? i will purchase the licenses in a short time, but i have to understand what kind of licenses i will use and i only will know after testing every profile.
thanks in advance
PS: i have some urgency in this cause i need to close my budget for the next year, this will be purchased in Q1, the colume will be no less than 500 ccusers
i am already using the eavluation license and i did every single step there, as you can see below:
Feature Version Count Available Expiry
Quadro-Virtual-DWS 5.0 64 63 2018-01-01
but i cant assign any of M60-4Q, M60-8Q, M6-4Q, M6-8Q profiles, what i read is that in order to have this profiles you have to run the 3.0 versionof somtheing (it was not clear)
Symptom/Error
NVIDIA GRID driver is unable to check out a license from the license server when using 4Q, 8Q or Passthrough profiles for the M60/M6 GRID cards. E.g. M60-4Q, M60-8Q, M6-4Q, M6-8Q profiles. Cause
Drivers prior to the 3.0 code release required a vWorkstation Extended license for 4GB or greater profiles.
Since March 2016 NVIDIA ceased to ship the Extended license as a result of the changes in licensing.
If customers / partners are deploying licenses acquired after March 2016 they will require the 3.0 or later driver bundle to use profiles larger than 2GB. Resolution
Update to 3.0 driver bundle or later. Advice on finding the drivers is detailed here: Error | NVIDIA
what bundle do i have and where i can check it ? is the Quadro-Virtual-DWS version 5.0 good enough for that ?
Everything you need is available in the software portal above. Make sure you’ve upgraded your GRID license server and installed the latest licenses which it looks like you have.
Then make sure your Hypervisors and VMs are running the latest GRID 5 software
If you are using ESXi then please check to see if the GPU consolidation is set to true.
ESXi host setting
Place this in the /etc/vmware/config file. (Add this line at the bottom of the file)
vGPU.consolidation = true
Or if you are running 6.5 you can set this within vCenter using the web interface.
There’s a homogeneous vGPU rule. This setting needs to be applied.
I would also check the vGPU profile you have attached to the parent image.
Without knowing which GRID driver you are using there is no further help possible. You won’t be able to aquire a license with GRID4.x driver when running the latest trial key which expects a GRID5.x driver.
