SN2100: MLNX-OS Rev 4.40 software version 3.6.1102
I’m following below steps
create vrf1
create 1st routed port Eth1/5 in vrf1
create 2nd routed port Eth1/6 in default-vrf
create 3rd routed port Eth1/7 in default-vrf
Observe mac address on all these interfaces are changed from their default values to a “router” mac address (which is set to system mac address 7c:fe:90:f8:e5:00 + 1)
The switch uses this “router” mac address as source mac instead of the per interface mac address on egress packets (say ping). why is this so ?
Specifically, can someone explain why
mac addresses for multiple interfaces within VRF are same.
mac addresses on interfaces across multiple VRFs are same.
One would expect to have a separate mac address at least per vrf level.
Thanks in advance for any help.
switch-2ce986 [standalone: master] # show run
vrf definition vrf1
ip routing vrf default
interface ethernet 1/5 no switchport force
interface ethernet 1/5 vrf forwarding vrf1
interface ethernet 1/6 no switchport force
interface ethernet 1/7 no switchport force
switch-2ce986 [standalone: master] # show interfaces ethernet 1/5
Eth1/5
Admin state: Enabled
Operational state: Down
Last change in operational status: Never
Description: N\A
Mac address: 7c:fe:90:f8:e5:01 <<<<<<<<<<<<<
MTU: 1500 bytes(Maximum packet size 1522 bytes)
Fec: auto
Flow-control: receive off send off
Actual speed: 40 Gbps
Width reduction mode: Not supported
DHCP client: Disabled
Arp timeout: 1500 seconds
VRF: vrf1 <<<<<<<<<<<<<
MAC learning mode: Enabled
Last clearing of “show interface” counters : Never
60 seconds ingress rate: 0 bits/sec, 0 bytes/sec, 0 packets/sec
60 seconds egress rate: 0 bits/sec, 0 bytes/sec, 0 packets/sec
switch-2ce986 [standalone: master] # show interfaces ethernet 1/6
Eth1/6
Description: N\A
Mac address: 7c:fe:90:f8:e5:01 <<<<<<<<<<<<<<
Fec: auto
VRF: default <<<<<<<<<<<<<<
Eth1/7
Description: N\A
Fec: auto
