can someone confirm these are the right steps to make a full backup of the jetson and restore the image. I want to make sure this works.
from Full backup Nvidia Jetson Xavier - Ayachips :
Creating the backup image file
You will need a PC running ubuntu with Nvidia sdk JetPack 4.2 and 64go of free space. From this PC, ssh to your jetson (jetson is running normaly, not on restore mode).
ssh jetsonUser@JetsonIP
On the Jetson, through this ssh, stop the filesystem and force it to read only access:
echo u > /proc/sysrq-trigger
Still on the jetson, through ssh, transferring an image of full internal memory hard drive over ssh to host PC:
dd if=/dev/mmcblk0p1 | ssh user@hostpc dd of=/media/aya/usbaya/image.raw
I am creating the raw img file in my external drive for space issue. I
This will create on your PC a 30Gb file containing a full image of the Jetson. you can now turn of jetson.
Now on you pc you can convert the .raw image to a .img image file:
cd /home/aya/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888/Linux_for_Tegra/bootloader/
sudo ./mksparse -v --fillpattern=0 /media/aya/usbaya/image.raw /media/aya/usbaya/system.img
I am creating the img file in my external drive for space issue. I
Restoring the image file
Boot the Jetson on restore mode (power and middle button for 5 sec), connect it with usb to the PC.
copy in this bootloader folder your backup img file and rename it system.img
sudo ./flash.sh -r jetson-xavier mmcblk0p1
done.
Thanks and Regards
