Make the Xavier NX SOM work on Orin NX carrier board
The Orin NX carrier board only has DP1, which is DisplayPort connector. While Xavier NX has DP0 and DP1, which DP0 is DisplayPort and DP1 is HDMI in default. As I know.
When plug Xavier NX SOM in Orin NX carrier board. Can the DP1 work - light up a displayer? Note: using the default Xavier NX dts.
If this is default DTS, then it will not light up as a DP.
