Hello everyone,
I would like to run an NX Xavier chip on the Orin Nano Devkit. This exercise allows me to make progress in the design of my custom board. More specifically, I am interested in activating the DisplayPort on channel DP1 via PinMux to use the DisplayPort of the Orin Nano Devkit.
I have reviewed this topic and this topic. I hope to use PinMux to generate the correct configuration. However, for DP1 channel, in the Xavier’s PinMux, I am not able to select anything other than an HDMI signal. What should I do?
Moreover, I believe it is crucial to pay attention to the configuration of these yellow-highlighted pins (tell me if not) but I’m not exactly sure what configurations assign to them.
Unfortunately, no test has been successful so far.
PS: To make progress, I have compared it with the PinMux available for the Orin. In this case, several sheets are available, including one configuration for HDMI and one for DP. The only difference to switch between them is to change the configuration like this:
| Pin | DP | HDMI |
| 77 | DP0_TXDP2 | HDMI0_TXDP2 |
| 75 | DP0_TXDN2 | HDMI0_TXDN2 |
| 71 | DP0_TXDP1 | HDMI0_TXDP1 |
| 69 | DP0_TXDN1 | HDMI0_TXDN1 |
| 65 | DP0_TXDP0 | HDMI0_TXDP0 |
| 63 | DP0_TXDN0 | HDMI0_TXDN0 |
| 83 | DP0_TXDP3 | HDMI0_TXDP3 |
| 81 | DP0_TXDN3 | HDMI0_TXDN3 |
Unfortunately, this option does not exist in the Xavier PinMux.
| Pin | DP | HDM |
| 100 | DP_AUX_CH0_P | I2C6_CLK |
| 98 | DP_AUX_CH0_N | I2C6_DAT |
| 96 | DP_AUX_CH0_HPD | GPIO3_PM.00 |
