Looks like makelocalrc cannot find the strings library…?
I’m installing as root on a VMware ESXi vm running Ubuntu 10.04 LTS Server x86_64:
root@euclid:/tmp/pgi# uname -a
Linux euclid 2.6.32-30-server #59-Ubuntu SMP Tue Mar 1 22:46:09 UTC 2011 x86_64 GNU/Linux
…down into the install…
Installation directory? [/opt/pgi]
Note: created directory /opt/pgi
Installing selected PGI CDK components into /opt/pgi
This might take awhile ...
Creating /opt/pgi/linux86-64/11.5/bin/localrc
/opt/pgi/linux86-64/11.5/bin/makelocalrc: 451: strings: not found
ERROR: unknown glibc version ().
This release of PGI software includes the JAVA JRE 6.0_21. PGI's graphical
debugger and profiler use components from this package.
If you have installed JAVA JRE 6.0_21 with a previous PGI 2011 release,
or in a separate PGI 2011 download, you do not need to install it again.
Install JAVA JRE 6.0_21? (y/n) n
Installing ACML components into /opt/pgi
Installing PGI CUDA components into /opt/pgi
This install is for a small compile farm, so it’s not using MPI (I selected Option 1 then option 6 on the install menu). However, I will be doing a full cluster install on bare metal in 2 months or so. It would be nice to have this issue understood before then.
Thanks,
Phil
