xorg.0.log
[ 24.666]
X.Org X Server 1.20.5
X Protocol Version 11, Revision 0
[ 24.666] Build Operating System: Linux Arch Linux
[ 24.666] Current Operating System: Linux edwardM 5.2.11-1-MANJARO #1 SMP PREEMPT Thu Aug 29 07:41:24 UTC 2019 x86_64
[ 24.666] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.2-x86_64 root=UUID=1e6b9bac-58b4-4b3c-ac82-7fe6db78b537 rw quiet apparmor=1 security=apparmor resume=UUID=f3cfa22c-be47-459a-bf7d-e2eb5015973c udev.log_priority=3
[ 24.666] Build Date: 14 August 2019 10:50:56PM
[ 24.666]
[ 24.666] Current version of pixman: 0.38.4
[ 24.666] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 24.666] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 24.667] (==) Log file: “/var/log/Xorg.0.log”, Time: Fri Oct 11 17:16:37 2019
[ 24.667] (==) Using config directory: “/etc/X11/xorg.conf.d”
[ 24.667] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 24.667] (==) ServerLayout “layout”
[ 24.667] () |–>Screen “Screen0” (0)
[ 24.667] () | |–>Monitor “Monitor0”
[ 24.667] () | |–>Device “Device0”
[ 24.667] (==) Automatically adding devices
[ 24.667] (==) Automatically enabling devices
[ 24.667] (==) Automatically adding GPU devices
[ 24.667] (==) Automatically binding GPU devices
[ 24.667] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 24.667] (WW) The directory “/usr/share/fonts/OTF” does not exist.
[ 24.667] Entry deleted from font path.
[ 24.667] (WW) The directory “/usr/share/fonts/Type1” does not exist.
[ 24.667] (WW) fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi". [ 24.667] Entry deleted from font path. [ 24.667] (Run 'mkfontdir' on "/usr/share/fonts/100dpi"). [ 24.667] (WW) fonts.dir’ not found (or not valid) in “/usr/share/fonts/75dpi”.
[ 24.667] (Run ‘mkfontdir’ on “/usr/share/fonts/75dpi”).
[ 24.667] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 24.667] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 24.667] (**) Extension “COMPOSITE” is enabled
[ 24.667] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 24.667] (II) Module ABI versions:
[ 24.667] X.Org ANSI C Emulation: 0.4
[ 24.667] X.Org Video Driver: 24.0
[ 24.667] X.Org XInput driver : 24.1
[ 24.667] X.Org Server Extension : 10.0
[ 24.668] (++) using VT number 7
[ 24.668] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 24.669] (–) PCI:*(1@0:0:0) 10de:1401:103c:2b4d rev 161, Mem @ 0xde000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x???/131072
[ 24.669] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 24.669] (II) LoadModule: “glx”
[ 24.669] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 24.670] (II) Module glx: vendor=“X.Org Foundation”
[ 24.670] compiled for 1.20.5, module version = 1.0.0
[ 24.670] ABI class: X.Org Server Extension, version 10.0
[ 24.670] (II) LoadModule: “nvidia”
[ 24.670] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 24.670] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 24.670] compiled for 1.6.99.901, module version = 1.0.0
[ 24.670] Module class: X.Org Video Driver
[ 24.670] (II) NVIDIA dlloader X Driver 435.21 Sun Aug 25 08:17:08 CDT 2019
[ 24.670] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 24.670] (II) Loading sub module “fb”
[ 24.670] (II) LoadModule: “fb”
[ 24.670] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 24.670] (II) Module fb: vendor=“X.Org Foundation”
[ 24.670] ABI class: X.Org ANSI C Emulation, version 0.4
[ 24.670] (II) Loading sub module “wfb”
[ 24.670] (II) LoadModule: “wfb”
[ 24.670] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 24.670] (II) Module wfb: vendor=“X.Org Foundation”
[ 24.670] (II) Loading sub module “ramdac”
[ 24.670] (II) LoadModule: “ramdac”
[ 24.670] (II) Module “ramdac” already built-in
[ 24.805] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[ 24.805] (EE) NVIDIA: system’s kernel log for additional error messages and
[ 24.805] (EE) NVIDIA: consult the NVIDIA README for details.
[ 24.805] (EE) No devices detected.
[ 24.805] (EE)
Fatal server error:
[ 24.805] (EE) no screens found(EE)
[ 24.805] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 24.805] (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
[ 24.805] (EE)
[ 24.830] (EE) Server terminated with error (1). Closing log file.
journalctl -xe -p3 -b > ManLog.txt
– Logs begin at Fri 2019-10-11 16:02:16 KST, end at Sat 2019-10-12 06:24:15 KST. –
Oct 12 06:22:30 edwardM kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
Oct 12 06:22:30 edwardM kernel: ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [D128] at bit offset/length 128/1024 exceeds size of target Buffer (160 bits) (20190509/dsopcode-198)
Oct 12 06:22:30 edwardM kernel: ACPI Error: Aborting method \HWMC due to previous error (AE_AML_BUFFER_LIMIT) (20190509/psparse-529)
Oct 12 06:22:30 edwardM kernel: ACPI Error: Aborting method _SB.WMID.WMAA due to previous error (AE_AML_BUFFER_LIMIT) (20190509/psparse-529)
Oct 12 06:22:30 edwardM kernel: kvm: disabled by bios
Oct 12 06:22:30 edwardM kernel: Bluetooth: hci0: unexpected event for opcode 0xfc2f
Oct 12 06:22:26 edwardM systemd-modules-load[323]: Failed to insert module ‘nvidia’: Invalid argument
Oct 12 06:22:27 edwardM systemd-modules-load[323]: Failed to insert module ‘nvidia_drm’: Invalid argument
Oct 12 06:22:27 edwardM systemd[1]: Failed to start Load Kernel Modules.
– Subject: A start job for unit systemd-modules-load.service has failed
– Defined-By: systemd
– Support: https://forum.manjaro.org/c/technical-issues-and-assistance
– A start job for unit systemd-modules-load.service has finished with a failure.
– The job identifier is 48 and the job result is failed.
Oct 12 06:22:29 edwardM systemd-modules-load[580]: Failed to insert module ‘nvidia’: Invalid argument
Oct 12 06:22:29 edwardM systemd-modules-load[580]: Failed to insert module ‘nvidia_drm’: Invalid argument
Oct 12 06:22:29 edwardM systemd[1]: Failed to start Load Kernel Modules.
– The job identifier is 176 and the job result is failed.
Oct 12 06:22:30 edwardM systemd-modules-load[590]: Failed to insert module ‘nvidia’: Invalid argument
Oct 12 06:22:30 edwardM systemd-modules-load[590]: Failed to insert module ‘nvidia_drm’: Invalid argument
Oct 12 06:22:30 edwardM systemd[1]: Failed to start Load Kernel Modules.
– The job identifier is 397 and the job result is failed.
Oct 12 06:22:40 edwardM systemd[1]: Failed to start Light Display Manager.
– Subject: A start job for unit lightdm.service has failed
– A start job for unit lightdm.service has finished with a failure.
– The job identifier is 1207 and the job result is failed.
Oct 12 06:24:14 edwardM kernel: scsi 6:0:0:0: rejecting I/O to dead device
inxi -MGCN (hardware Other computer no problem with different Nvidia card)
NOTE I was running Linux mint when I ran this. Same Computer different OS
edward@edward4:~$ inxi -MGCNA
Machine:
Type: Desktop Mobo: HP model: 2B4B v: 1.04 serial:
UEFI [Legacy]: AMI v: A0.14 date: 06/06/2016
CPU:
Topology: Quad Core model: Intel Core i7-6700 bits: 64 type: MT MCP
L2 cache: 8192 KiB
Speed: 3700 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 3700 2: 3700
3: 3700 4: 3700 5: 3700 6: 3700 7: 3700 8: 3700
Graphics:
Device-1: NVIDIA GM206 [GeForce GTX 960] driver: nvidia v: 430.26
Display: x11 server: X.Org 1.19.6 driver: nvidia
unloaded: fbdev,modesetting,nouveau,vesa resolution: 1920x1080~60Hz
OpenGL: renderer: GeForce GTX 960/PCIe/SSE2 v: 4.6.0 NVIDIA 430.26
Audio:
Device-1: Intel 100 Series/C230 Series Family HD Audio
driver: snd_hda_intel
Device-2: NVIDIA driver: snd_hda_intel
Device-3: Logitech G430 Surround Sound Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound Server: ALSA v: k4.15.0-20-generic
Network:
Device-1: Intel Wireless 3165 driver: iwlwifi
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
driver: r8169
