You can check the source of …/kernel/nvidia/drivers/spi/spi-tegra114.c
Related topics
| Issue with CS signal | 3 | 586 | December 20, 2018 | |
| Is the TX2 support SPI1_CS1 (E13) pin controller function? | 1 | 512 | January 10, 2019 | |
| TX1 SPI Hardware CS incorrect behavior using regmap | 5 | 852 | October 18, 2021 | |
| Configure two spi devices on same spi interface | 3 | 1021 | October 18, 2021 | |
| TX2 R28.2 SPI CS-GPIO issue | 2 | 1470 | October 18, 2021 | |
| Multiple SPI devices on Jetson TK1 | 0 | 826 | March 11, 2015 | |
| Did anybody get SPI interface working on TX1? | 37 | 12263 | October 18, 2021 | |
| Multiple TX2 SPI slave select with GPIO in dtb | 2 | 1345 | October 18, 2021 | |
| SPI slave can only receive the second packet from Nano dev kit SPI master | 56 | 4172 | January 16, 2020 | |
| SPIdev cannot use CS0 on L4T 21.3 and above | 13 | 3497 | November 13, 2016 |
