Massflash orin nx method
I learned the massflash notice “Workflow 3: To massflash the backup image is currently not working for Jetson Orin NX. In addition, a Jetson device needs to have an SD card or NVMe SSD attached to be able to use this tool.”
I’ve a orin nx board, with jetpack 6.2 and app installed. Below backup and restore cmd works well now. But looks like it can only flash one device once?
sudo ./tools/backup_restore/l4t_backup_restore.sh -e nvme0n1 -b jetson-orin-nano-devkit
sudo ./tools/backup_restore/l4t_backiup_restore.sh -e nvme0n1 -r jetson-orin-nano-devkit
Could you suggest a better method to do the massflash?
For example, a nvme ssd with jetpack and app installed. Copy the ssd all files to another new ssd, and then install the new ssd to new orin nx. Is it work?
We will contact the internal team to check whether the Note is outdated.
The massflash backup image do support Orin NX in theory, but we need to take some time to reconfirm.
We verify Orin NX supported in Workflow3.
You could follow the guideline to mass flash your Orin NX.
Thank you for confirm, DavidDDD
