I create an extension with omni.ui.
It runs OK in USD Composer 2022.3.3.
But in 2023.1.1, it generate amount of message as following.
2023-09-01 02:10:22 [Info] [carb] Plugin omni.ui is already a dependency of omni.ui.glyphmanager.plugin; not changing unload order
And the following is imported module.
from pxr import Usd, UsdGeom, UsdSkel, Gf, Tf
import omni.ext
from omni.ui import color as cl
from omni.ui import scene as sc
import omni.ui as ui
import omni.kit
import omni.kit.app
import omni.kit.viewport.utility
import carb
import carb.events
import inspect
import time
import os
import numpy as np
import math
And, an error occurred when enbaled in Create XR 2.22.2.0-rel.1
Error: cannot import name ‘scene’ from ‘omni.ui’
How to resolve it.
Best regards.
