Install omni.example.ui_scene.widget_info error
Hi, I tried to install omni.example.ui_scene.widget_info error in extensions for NVIDIA Training Solutions | NVIDIA.
But it showed these errors after clicking install
2022-10-28 09:19:30 [165,552ms] [Info] [omni.kit.registry.nucleus.utils] [omni.kit.registry.nucleus]: result: Result.OK
2022-10-28 09:19:30 [165,552ms] [Info] [omni.kit.registry.nucleus.utils] [omni.kit.registry.nucleus]: downloading: 'https://github.com/NVIDIA-Omniverse/kit-workshop-siggraph2022/archive/refs/tags/v1.0.1.zip' -> '/tmp/tmpmjhjjjax/omni.example.ui_scene.widget_info-1.0.1+cp37.zip'...
2022-10-28 09:19:30 [165,552ms] [Info] [omni.kit.app.impl] [py stdout]: [omni.kit.registry.nucleus]: [omni.kit.registry.nucleus]: downloading: 'https://github.com/NVIDIA-Omniverse/kit-workshop-siggraph2022/archive/refs/tags/v1.0.1.zip' -> '/tmp/tmpmjhjjjax/omni.example.ui_scene.widget_info-1.0.1+cp37.zip'...
2022-10-28 09:19:30 [165,552ms] [Info] [omni.kit.registry.nucleus.utils] [omni.kit.registry.nucleus]: (downloading ext archive) copying: https://github.com/NVIDIA-Omniverse/kit-workshop-siggraph2022/archive/refs/tags/v1.0.1.zip -> /tmp/tmpmjhjjjax/omni.example.ui_scene.widget_info-1.0.1+cp37.zip
2022-10-28 09:19:30 [165,651ms] [Info] [omni.kit.registry.nucleus.utils] [omni.kit.registry.nucleus]: result: Result.OK
2022-10-28 09:19:30 [165,651ms] [Info] [omni.kit.registry.nucleus.utils] [omni.kit.registry.nucleus]: unpacking: /tmp/tmpmjhjjjax/omni.example.ui_scene.widget_info-1.0.1+cp37.zip -> /home/matt.chen/.cache/ov/exts/3
2022-10-28 09:19:30 [165,651ms] [Info] [omni.kit.app.impl] [py stdout]: [omni.kit.registry.nucleus]: [omni.kit.registry.nucleus]: unpacking: /tmp/tmpmjhjjjax/omni.example.ui_scene.widget_info-1.0.1+cp37.zip -> /home/matt.chen/.cache/ov/exts/3
2022-10-28 09:19:30 [165,658ms] [Info] [omni.ext.impl] [omni.ext] unpack_archive: '/tmp/tmpmjhjjjax/omni.example.ui_scene.widget_info-1.0.1+cp37.zip' to '/tmp/tmpmx9rxhol'
2022-10-28 09:19:30 [165,662ms] [Info] [omni.kit.app.impl] [py stdout]: Unzipping: omni.example.ui_scene.widget_info-1.0.1+cp37.zip (57.1 MiB)
2022-10-28 09:19:30 [165,662ms] [Info] [omni.kit.app.impl] [py stdout]: No continuous progress report because this is not a proper terminal. Be patient ...
2022-10-28 09:19:30 [165,991ms] [Info] [omni.kit.app.impl] [py stdout]: 100% (speed 173 MiB/s)
2022-10-28 09:19:30 [165,991ms] [Info] [omni.kit.app.impl] [py stdout]: Total of 0.33 seconds
2022-10-28 09:19:30 [165,992ms] [Info] [omni.ext.impl] [omni.ext] copy: '/tmp/tmpmx9rxhol/kit-workshop-siggraph2022-1.0.1\exts\omni.example.ui_scene.widget_info' to '/home/matt.chen/.cache/ov/exts/3/omni.example.ui_scene.widget_info-1.0.1+cp37'
2022-10-28 09:19:30 [166,002ms] [Error] [omni.kit.app.impl] [py stderr]: Exception in thread Thread-6:
  File "/home/matt.chen/.local/share/ov/pkg/deps/8d41671562827ef6601e581c051e1f81/python/lib/python3.7/threading.py", line 926, in _bootstrap_inner
    self.run()
  File "/home/matt.chen/.local/share/ov/pkg/deps/8d41671562827ef6601e581c051e1f81/python/lib/python3.7/threading.py", line 870, in run
    self._target(*self._args, **self._kwargs)
  File "/home/matt.chen/.local/share/ov/pkg/deps/8d41671562827ef6601e581c051e1f81/extscore/omni.kit.registry.nucleus/omni/kit/registry/nucleus/registry.py", line 834, in unpack
    omni.ext.unpack_extension(archive_local, cache_path, ext_id=ext_id, archive_subdir=archive_subdir)
  File "/home/matt.chen/.local/share/ov/pkg/deps/8d41671562827ef6601e581c051e1f81/plugins/bindings-python/omni/ext/impl/__init__.py", line 155, in unpack_extension
    shutil.copytree(subdir, extract_to)
  File "/home/matt.chen/.local/share/ov/pkg/deps/8d41671562827ef6601e581c051e1f81/python/lib/python3.7/shutil.py", line 318, in copytree
    names = os.listdir(src)
FileNotFoundError: [Errno 2] No such file or directory: '/tmp/tmpmx9rxhol/kit-workshop-siggraph2022-1.0.1\\exts\\omni.example.ui_scene.widget_info'
2022-10-28 09:19:30 [166,011ms] [Error] [omni.ext.python] PythonRegistryProvider.pull_extension_async() failed. Error: TypeError: expected str, bytes or os.PathLike object, not NoneType
At:
  /home/matt.chen/.local/share/ov/pkg/deps/8d41671562827ef6601e581c051e1f81/python/lib/python3.7/posixpath.py(80): join
  /home/matt.chen/.local/share/ov/pkg/deps/8d41671562827ef6601e581c051e1f81/extscore/omni.kit.registry.nucleus/omni/kit/registry/nucleus/registry.py(859): _finalize_install
  /home/matt.chen/.local/share/ov/pkg/deps/8d41671562827ef6601e581c051e1f81/extscore/omni.kit.registry.nucleus/omni/kit/registry/nucleus/registry.py(846): _pull_extension_async
2022-10-28 09:19:33 [168,524ms] [Info] [omni.kit.menu.utils.scripts.utils] omni.kit.menu.utils.refresh_menu_items Window False
How to fix this?
The log: kit_20221028_021644.log (1.0 MB)
Hi @q199493422. I didn’t have any problem downloading it on Windows. I’ll have someone try on Linux to see if we can reproduce it.
Sorry for the delay on this. We’ve confirmed the issue and log an internal ticket for it: OM-72657. Thanks for reporting!
The devs tell me this is fixed now. Please try the extension again. :)
