I have installed create-2021.1.0 on an Ubuntu-20.04.2 installation with an NVIDIA Quadro RTX 5000 GPU.
When I run omni.create.testing.sh, I get the following errors:
2021-04-12 14:46:21 [104,729ms] [Warning] [omni.usd] Warning (secondary thread): in Tf_PyLoadScriptModule at line 122 of /buildAgent/work/ca6c508eae419cf8/USD/pxr/base/tf/pyUtils.cpp -- Import failed for module 'pxr.PhysxSchema'!
2021-04-12 14:46:21 [104,729ms] [Warning] [omni.client.plugin] 140266105792256: usd_plugin: Import failed for module 'pxr.PhysxSchema'!
2021-04-12 14:46:21 [104,729ms] [Error] [carb.python] [py stderr]: Traceback (most recent call last):
2021-04-12 14:46:21 [104,729ms] [Error] [carb.python] [py stderr]: File "/home/user/.local/share/ov/pkg/create-2021.1.0/_build/kit_release/_build/linux-x86_64/release/plugins/bindings-python/pxr/PhysxSchema/__init__.py", line 30, in <module>
2021-04-12 14:46:21 [104,730ms] [Error] [carb.python] [py stderr]:
2021-04-12 14:46:21 [104,730ms] [Error] [carb.python] [py stderr]: from . import _physxSchema
2021-04-12 14:46:21 [104,730ms] [Error] [carb.python] [py stderr]: SystemError
2021-04-12 14:46:21 [104,730ms] [Error] [carb.python] [py stderr]: :
2021-04-12 14:46:21 [104,730ms] [Error] [carb.python] [py stderr]: initialization of _physxSchema raised unreported exception
SystemError: initialization of _physxSchema raised unreported exception
2021-04-12 14:48:19 [223,260ms] [Warning] [omni.usd] Warning: in SdfPath at line 97 of /buildAgent/work/ca6c508eae419cf8/USD/pxr/usd/sdf/path.cpp -- Ill-formed SdfPath <>: syntax error
2021-04-12 14:48:19 [223,260ms] [Warning] [omni.client.plugin] Main: usd_plugin: Ill-formed SdfPath <>: syntax error
2021-04-12 14:48:19 [223,260ms] [Error] [carb.events.python] AttributeError: module 'omni.kit' has no attribute 'builtin'
At:
/home/user/.local/share/ov/pkg/create-2021.1.0/_build/kit_release/_exts/omni.kit.context_menu/omni/kit/context_menu.py(282): build_create_menu
/home/user/.local/share/ov/pkg/create-2021.1.0/_build/kit_release/_exts/omni.kit.window.viewport/omni/kit/viewport/scripts/context_menu.py(316): show_create_menu
/home/user/.local/share/ov/pkg/create-2021.1.0/_build/kit_release/_exts/omni.kit.context_menu/omni/kit/context_menu.py(749): _build_menu
/home/user/.local/share/ov/pkg/create-2021.1.0/_build/kit_release/_exts/omni.kit.context_menu/omni/kit/context_menu.py(790): show_context_menu
/home/user/.local/share/ov/pkg/create-2021.1.0/_build/kit_release/_exts/omni.kit.window.viewport/omni/kit/viewport/scripts/context_menu.py(210): on_mouse_event
2021-04-12 14:48:36 [240,541ms] [Error] [carb.events.python] AttributeError: module 'omni.kit' has no attribute 'builtin'
At:
