Hey!
I’m trying to enable Omniverse Visual Debugger to debug my Physx application. But for some reason, when running Create app, the omni.physx plugin fails to load.
(Note that I have tried with 2022.3.3 and 2022.3.1 versions and both gave me the same error)
You can see the log output in the creator.log attached file. And the console log I can’t attach since I’m a new user and it only allows to upload one file for new users. But more or less had the same info.
I believe this is the relevant first error:
[4.535s] [ext: omni.physx-104.1.6-5.1] startup 2023-05-29 09:04:08 [4,481ms] [Warning] [carb] [Plugin: libomni.physx.plugin.so] Could not locate the function: carbGetFrameworkVersion
2023-05-29 09:04:08 [4,481ms] [Warning] [carb] Potential plugin preload failed: /home/lpares/.local/share/ov/pkg/deps/82b461274b877b7d5e1a405066cfd47a/extsPhysics/omni.physx-104.1.6-5.1/bin/libomni.physx.plugin.so
2023-05-29 09:04:08 [4,481ms] [Error] [omni.ext.plugin] [ext: omni.physx-104.1.6-5.1] failed to load native plugin:
I’m running it in Ubuntu 20.04, with integrated Intel graphics.
Any help will be appreciated!
console.log (1.1 MB)
