Hi.
Datasheet for Jetson Nano states it could output up to 4k60 via HDMI which is great. What about FHD resolution and refresh rates higher than 60hz? Are there any obstacles to have 1080p144hz on Jetson Nano, given the monitor supports such mode? What is the maximum refresh rate for 1080p HDMI output Jetson Nano supports?
The maximum pclk we support is 594Mhz on jetson nano.
Thus, if your display mode not exceeds this pclk, then jetson nano shall support.
Thank you!
