MAXN does not appear after install on SD or NVMe
I’m running it now- I selected everything in the list, too. I’m trying the nvme installation first. I will attach those logs first.
Then I can try via SD card if you want.
My nvme is a 2TB Samaung 990 EVO
The flash card is a 128GB flash card my sandisk extreme up to 190mb/sec
I also selected the 8GB dev board.
It usually failed during the flash step at around 75%. I’ll screencap that, too and send you the logs when they’re done
So good news!
It successfully flashed and is now installing all the software. The only difference I did from before:
  1. I removed the short right after it connected
  2. I stopped bluetooth on my linux machine (I read on another reply that bluetooth gets in the way)
This allowed the machine to restart and show the screen. I logged in the machine successfully and looked at the IP address it assigned. I connected to the machine this way instead. Right now it’s installing a ton of software.
I’ll wait for the install to complete. If you don’t mind, let’s leave this open until it’s successful.
I’m also connected over ethernet instead of wireless, this may have helped too? Not sure.
OK - it worked! All packages successfully installed via NVMe without the SD card with flashing. Can’t ask for more than this :)
lscpu returns what’s expected and MAXN was shown OOTB (as you’d expect!)
krickert@ubuntu:~$ lscpu
Architecture:            aarch64
  CPU op-mode(s):        32-bit, 64-bit
  Byte Order:            Little Endian
CPU(s):                  6
  On-line CPU(s) list:   0-5
Vendor ID:               ARM
  Model name:            Cortex-A78AE
    Model:               1
    Thread(s) per core:  1
    Core(s) per cluster: 3
    Socket(s):           -
    Cluster(s):          2
    Stepping:            r0p1
    CPU max MHz:         1728.0000
    CPU min MHz:         115.2000
    BogoMIPS:            62.50
    Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp
                          asimdhp cpuid asimdrdm lrcpc dcpop asimddp uscat ilrcp
                         c flagm paca pacg
Caches (sum of all):
  L1d:                   384 KiB (6 instances)
  L1i:                   384 KiB (6 instances)
  L2:                    1.5 MiB (6 instances)
  L3:                    4 MiB (2 instances)
NUMA:
  NUMA node(s):          1
  NUMA node0 CPU(s):     0-5
Vulnerabilities:
  Gather data sampling:  Not affected
  Itlb multihit:         Not affected
  L1tf:                  Not affected
  Mds:                   Not affected
  Meltdown:              Not affected
  Mmio stale data:       Not affected
  Retbleed:              Not affected
  Spec rstack overflow:  Not affected
  Spec store bypass:     Mitigation; Speculative Store Bypass disabled via prctl
  Spectre v1:            Mitigation; __user pointer sanitization
  Spectre v2:            Mitigation; CSV2, but not BHB
  Srbds:                 Not affected
  Tsx async abort:       Not affected
krickert@ubuntu:~$
The the tegrastats:
01-03-2025 00:43:41 RAM 3121/7620MB (lfb 1x4MB) SWAP 0/3810MB (cached 0MB) CPU [7%@729,10%@729,13%@729,8%@729,5%@729,6%@729] EMC_FREQ 3%@2133 GR3D_FREQ 0%@[305] NVDEC off NVJPG off NVJPG1 off VIC off OFA off APE 200 cpu@49.531C soc2@48.062C soc0@49.093C gpu@49.75C tj@51.156C soc1@51.156C VDD_IN 6309mW/6309mW VDD_CPU_GPU_CV 792mW/792mW VDD_SOC 2023mW/2023mW
01-03-2025 00:43:42 RAM 3121/7620MB (lfb 1x4MB) SWAP 0/3810MB (cached 0MB) CPU [5%@1728,3%@1728,3%@1021,3%@729,0%@729,0%@729] EMC_FREQ 2%@2133 GR3D_FREQ 0%@[305] NVDEC off NVJPG off NVJPG1 off VIC off OFA off APE 200 cpu@49.312C soc2@48.062C soc0@49.187C gpu@49.718C tj@51.062C soc1@51.062C VDD_IN 5952mW/6131mW VDD_CPU_GPU_CV 554mW/673mW VDD_SOC 2020mW/2022mW
01-03-2025 00:43:43 RAM 3121/7620MB (lfb 1x4MB) SWAP 0/3810MB (cached 0MB) CPU [5%@1587,3%@729,2%@729,3%@729,4%@729,0%@729] EMC_FREQ 2%@2133 GR3D_FREQ 0%@[305] NVDEC off NVJPG off NVJPG1 off VIC off OFA off APE 200 cpu@49C soc2@48.093C soc0@49.125C gpu@49.625C tj@50.968C soc1@50.968C VDD_IN 5991mW/6084mW VDD_CPU_GPU_CV 594mW/647mW VDD_SOC 2020mW/2021mW
01-03-2025 00:43:44 RAM 3122/7620MB (lfb 1x4MB) SWAP 0/3810MB (cached 0MB) CPU [5%@1728,8%@729,3%@729,3%@729,1%@729,3%@729] EMC_FREQ 2%@2133 GR3D_FREQ 0%@[305] NVDEC off NVJPG off NVJPG1 off VIC off OFA off APE 200 cpu@49.156C soc2@47.906C soc0@49.031C gpu@49.687C tj@50.968C soc1@50.968C VDD_IN 5991mW/6061mW VDD_CPU_GPU_CV 594mW/634mW VDD_SOC 2020mW/2021mW
nvidia-smi:
$ nvidia-smi
Fri Jan  3 00:41:38 2025
| NVIDIA-SMI 540.4.0                Driver Version: 540.4.0      CUDA Version: 12.6     |
| GPU  Name                 Persistence-M | Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp   Perf          Pwr:Usage/Cap |         Memory-Usage | GPU-Util  Compute M. |
|                                         |                      |               MIG M. |
|   0  Orin (nvgpu)                  N/A  | N/A              N/A |                  N/A |
| N/A   N/A  N/A               N/A /  N/A | Not Supported        |     N/A          N/A |
|                                         |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                            GPU Memory |
|        ID   ID                                                             Usage      |
|  No running processes found                                                           |
I can attach the logs too, that’s on my other machine and I’ll add that if it helps troubleshoot anyone else.
By the way - I can see that this is a very complicated install. Kudos to your team to set such a complex setup in such a small package! It is impressive. There’s no way I could write this in one swoop - I can see why my manual install wasn’t going to work given the complexity of dependencies.
Thanks for getting me to redo this. Once I got sdkmanager over the hump (turning off bluetooth, using ethernet instead, logging into the machine after startup all seems to have contributed to everything working).
Here’s the output of the install
I already have basic models running and have open-ui running. So it’s working like a charm.
So in the long run, I did follow the directions - I think that the linux host machine - being my intel machine running ubuntu linux - needs to have bluetooth turned off during this process. I also had the nano connectivity done thorough ssh and not the default setting to use the USB serial cable. Regardless, I think I understand enough about the installation now to do this again should the need arise.
Thanks for your prompt replies. Appreciate it.
