MCP2518FD can't send with JetPack 6.0
Continuing the discussion from MCP2518FD not working with JetPack 6.0 GA:
Hello, I am currently facing this issue as well.
When using Jetpack 5.1.2, mcp2518fd can work normally, but when using Jetpack 6.0, it can only receive and cannot send.
Do you have a solution now?
Looking forward to your reply, thank you.
Please refer to the steps for MCP2515 and see if it works for MCP2518:
Jetson/L4T/peripheral/ - eLinux.org
And would be great if you can upgrade to Jetpack 6.1.
Hello, the current configuration is basically the same.
I only added mcp251xfd during kernel loading, without adding mcp251x. Does this have any impact?
I have tried upgrading to Jetpack 6.1, and the phenomenon is the same as Jetpack 6.0.
It seems like CONFIG_CAN_MCP251X is also required. Does the vendor suggest you not to enable it? Probably you can also enable it and try.
Hello, I have joined mcp251x now, but it still doesn’t work.
Please apply this to overwrite SPI driver:
MCP2518FD not working with JetPack 6.0 GA - #22 by sevm89
