I need to connect a Mellanox SN3700V 200GbE to a Cisco router with 10Gbps SFP+ ports. Is this possible using some type of breakout cable?
If not the case, what is the the lowest interface speed I can convert from a 200Gbps port?
This question will require more in-depth investigation than is possible through a forum. A support request would be the best way to resolve this issue.
