Please check How to Carry out DMA transfer when sending data using PCIe from NVIDIA Root Port to a custom end point if can help.
kayccc
4
Related topics
| AGX Xavier Shared memory transfer large files | 5 | 575 | December 1, 2023 | |
| PCIe Address Size Upgrade | 1 | 386 | March 13, 2024 | |
| Xavier Endpoint increase the BAR size to 2G B | 1 | 402 | December 25, 2023 | |
| Transferring data using PCIe between Orin and Xavier | 4 | 151 | December 4, 2024 | |
| Xavier Endpoint increase the BAR size to 2G B | 2 | 633 | December 25, 2023 | |
| Jetson AGX Xavier PCIe Endpoint Mode | 2 | 472 | March 31, 2021 | |
| Jetson agx xavier inbound configuration of PCIe(root) | 6 | 598 | February 5, 2024 | |
| PCIe Root Complex DMA Test | 10 | 1710 | November 29, 2023 | |
| What is the actual maximum speed of Jetson AGX Xavier PCIE Ethernet? | 13 | 3932 | May 5, 2022 | |
| Xavier in EP mode(shared memory), the default size is [size=64K], but it can only be used 4KB | 3 | 356 | June 11, 2024 |
