Transferring data using PCIe between Orin and Xavier
I have connected an Jetson Orin AGX (endpoint) and Xavier using PCIe (root).
I followed the instructions in PCIe Endpoint Mode — Jetson Linux Developer Guide documentation
And I also increased the size on BAR0 in nvidia/drivers/pci/endpoint/functions/pci-epf-nv-test.c in the endpoint to 128M.
I see on the root that the endpoint is enumerated correctly, and I see the 128MB non-prefetchable memory.
I was successfully able to send across a “Hello World!” from endpoint using mmap() and memcpy() functions, and I was able to read it back as well.
However, I tried sending a 20KB text file from endpoint, and I could read back only 4KB on the root (the rest of the data was just garbage). I was wondering how to debug this.
Any help would be really appreciated.
Here are some suggestions for the common issues:
1. Performance
Please run the below command before benchmarking deep learning use case:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
2. Installation
Installation guide of deep learning frameworks on Jetson:
3. Tutorial
Startup deep learning tutorial:
4. Report issue
If these suggestions don’t help and you want to report an issue to us, please attach the model, command/step, and the customized app (if any) with us to reproduce locally.
@carolyuu your response is not related to PCIe :)
please check
https://forums.developer.nvidia.com/t/xavier-in-ep-mode-shared-memory-the-default-size-is-size-64k-but-it-can-only-be-used-4kb/295797/6
@WayneWWW Thank you for your response!
So in this case, should I just do a memcpy() our data into the output we get for pci_epf_nv_test.0: BAR0 RAM virt or the pci_epf_nv_test.0: BAR0 RAM IOVA:?
(edit: Neither worked)
