I have some doubts about the Jetson AGX Orin as PCIe Endpoint:
The PCIe RC requesting DMA transfers to Jetson EP, vice versa. Is it possible to implement DMA in this setup?
Another endpoint sending an MSI over p2p message. Is it possible to handle the MSI in this Jetson EP?
Here are some suggestions for the common issues:
1. Performance
Please run the below command before benchmarking deep learning use case:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
2. Installation
Installation guide of deep learning frameworks on Jetson:
3. Tutorial
Startup deep learning tutorial:
4. Report issue
If these suggestions don’t help and you want to report an issue to us, please attach the model, command/step, and the customized app (if any) with us to reproduce locally.
The sample pcie example we provided there shall already have DMA implementation.
Is the sample pcie example available for L4T 36.3.0/ JetPack 6.0??
I can’t update my version to 36.4.
system
Closed
December 18, 2024, 3:09am
11
