The AGX Orin for example has several PCIe controllers , each with the capability to act as RC or EP.
Can I set some of them as RC and others as EPs in order to use them with PCIe Endpoint Mode?
If I activate the PCIe Ethernet mode, can I use any sockets based app to transfer the packets via PCIe instead TCP/UDP IP? I mean does it is transparent to the app (for example use iperf)?
The guide says i have to re-flash the Jetson in order for it to act as an endpoint.
My question is if the Jetson can use some ports as RCs (for controlling external NVMe SSD)
and some as EPs (for Ethernet over pcie use case) at the same time without any problems?
