I’m trying to run the metropolis quick started and I’m seeing some issues following this:
https://docs.nvidia.com/moj/setup/quick-start.html#install-application-bundle
After Docker compose Up, I can see all the containers being created but some of them are showing errors:
r
oot@jetson-agx-orin-devkit:~/ai_nvr# docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
91aa6f24b835 ubuntu "sh -c 'chmod 1777 /…" 42 minutes ago Up 42 minutes ai_nvr-moj-init-vst-1
a077357158b7 ubuntu "sh -c 'chmod 1777 /…" 42 minutes ago Up 42 minutes ai_nvr-moj-http-based-init-1
d4ae4a312d06 nvcr.io/e7ep4mig3lne/release/emdx-analytics-web-api:mmj_v1 "sh -c 'gunicorn --w…" 42 minutes ago Up 42 minutes emdx-webapi
54b0f74cae63 ubuntu "sh -c 'chmod 1777 /…" 42 minutes ago Up 42 minutes ai_nvr-moj-http-based-init-1
dc9af15e0a17 ubuntu "sh -c 'chmod 1777 /…" 42 minutes ago Up 42 minutes ai_nvr-moj-init-ds-1
8d1529f4df40 ubuntu "sh -c 'chmod 1777 /…" 42 minutes ago Up 42 minutes ai_nvr-moj-http-based-init-1
8d111d9f03ff redisfab/redistimeseries:master-arm64v8-jammy "docker-entrypoint.s…" 45 minutes ago Up 45 minutes redis
e5609f65d8af nvcr.io/e7ep4mig3lne/release/ialpha-ingress-arm64v8:0.8 "sh -c '/nginx.sh 2>…" 45 minutes ago Up 45 minutes ingress
If I look to some docker container logs, I can see this error:
root@jetson-agx-orin-devkit:~/ai_nvr# docker logs 91aa6f24b835
Ign:1 http://ports.ubuntu.com/ubuntu-ports jammy InRelease
Ign:2 http://ports.ubuntu.com/ubuntu-ports jammy-updates InRelease
Ign:3 http://ports.ubuntu.com/ubuntu-ports jammy-backports InRelease
Ign:4 http://ports.ubuntu.com/ubuntu-ports jammy-security InRelease
Err:1 http://ports.ubuntu.com/ubuntu-ports jammy InRelease
Temporary failure resolving 'ports.ubuntu.com'
Err:2 http://ports.ubuntu.com/ubuntu-ports jammy-updates InRelease
Err:3 http://ports.ubuntu.com/ubuntu-ports jammy-backports InRelease
Err:4 http://ports.ubuntu.com/ubuntu-ports jammy-security InRelease
Reading package lists...
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/jammy/InRelease Temporary failure resolving 'ports.ubuntu.com'
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/jammy-updates/InRelease Temporary failure resolving 'ports.ubuntu.com'
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/jammy-backports/InRelease Temporary failure resolving 'ports.ubuntu.com'
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/jammy-security/InRelease Temporary failure resolving 'ports.ubuntu.com'
W: Some index files failed to download. They have been ignored, or old ones used instead.
Building dependency tree...
Reading state information...
E: Unable to locate package netcat
/health-check-script.sh: line 13: nc: command not found
Waiting for service on port 6379
Any suggestion? How do I make sure the containers is running right after docker compose up?
