I have a mipi DSI panel monitor and I want to make it work with jetson nano board. So I used make menuconfig to configured mipi. Before I include the option <> NVIDIA Tegra DRM , it could build successfully. However, when I include the option <> NVIDIA Tegra DRM and exit with save, it couldn’t build successfully. So I disinclude it again, it couldn’t build successfully anyway.
Following is my menuconfig path :
->Device Drivers
->Graphics support
<*> NVIDIA Tegra DRM
ANY HELP!!!
[b]My build terminal is ’ make ARCH=64 O=$TEGRA_KERNEL_OUT ’
Following is build error:
In file included
from /home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/drivers/cry pto/tegra-se-nvhost.c:36:0:
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h: In functi on ‘nvhost_syncpt_read_ext_check’:
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h:487:2: err or: implicit declaration of function ‘host1x_syncpt_update_min’; did you mean ‘host1x_syncpt_read_min’? [-W error=implicit-function-declaration]
host1x_syncpt_update_min(syncpt);
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h: In functi on ‘nvhost_syncpt_is_expired_ext’:
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h:526:9: err or: implicit declaration of function ‘host1x_syncpt_is_expired’; did you mean ‘host1x_syncpt_base_id’? [-We rror=implicit-function-declaration]
return host1x_syncpt_is_expired(syncpt, thresh);
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h: In functi on ‘nvhost_syncpt_set_min_eq_max_ext’:
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h:535:2: err or: implicit declaration of function ‘host1x_syncpt_reset’; did you mean ‘host1x_syncpt_free’? [-Werror=imp licit-function-declaration]
host1x_syncpt_reset(syncpt);
host1x_syncpt_free
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h: In functi on ‘nvhost_intr_register_notifier’:
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h:553:9: err or: implicit declaration of function ‘host1x_intr_register_notifier’; did you mean ‘nvhost_intr_register_no tifier’? [-Werror=implicit-function-declaration]
return host1x_intr_register_notifier(syncpt, thresh, callback,
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h: In functi on ‘nvhost_sync_create_fence’:
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h:580:9: err or: implicit declaration of function ‘host1x_sync_create_fence’; did you mean ‘nvhost_sync_create_fence’? -Werror=implicit-function-declaration]
return host1x_sync_create_fence(host, (void *)pts, num_pts, name);
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h:580:9: err or: return makes pointer from integer without a cast [-Werror=int-conversion]
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h: In functi on ‘nvhost_sync_create_fence_fd’:
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h:592:9: err or: implicit declaration of function ‘host1x_sync_create_fence_fd’; did you mean ‘nvhost_sync_create_fence_ fd’? [-Werror=implicit-function-declaration]
return host1x_sync_create_fence_fd(host, (void *)pts, num_pts,
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h: In functi on ‘nvhost_sync_fdget’:
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h:598:9: err or: implicit declaration of function ‘host1x_sync_fdget’; did you mean ‘host1x_syncpt_get’? [-Werror=implic it-function-declaration]
return host1x_sync_fdget(fd);
host1x_syncpt_get
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h:598:9: err or: return makes pointer from integer without a cast [-Werror=int-conversion]
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h: In functi on ‘nvhost_sync_num_pts’:
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h:603:9: err or: implicit declaration of function ‘host1x_sync_num_fences’; did you mean ‘host1x_syncpt_free’? [-Werror= implicit-function-declaration]
return host1x_sync_num_fences(fence);
host1x_syncpt_free
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h: In functi on ‘nvhost_sync_pt_id’:
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h:608:9: err or: implicit declaration of function ‘host1x_sync_pt_id’; did you mean ‘host1x_syncpt_id’? [-Werror=implici t-function-declaration]
return host1x_sync_pt_id(pt);
host1x_syncpt_id
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h: In functi on ‘nvhost_sync_pt_thresh’:
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h:613:9: err or: implicit declaration of function ‘host1x_sync_pt_thresh’; did you mean ‘nvhost_sync_pt_thresh’? [-Werro r=implicit-function-declaration]
return host1x_sync_pt_thresh(pt);
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h: In functi on ‘nvhost_sync_fence_set_name’:
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h:618:9: err or: implicit declaration of function ‘host1x_sync_fence_set_name’; did you mean ‘nvhost_sync_fence_set_nam ’? [-Werror=implicit-function-declaration]
return host1x_sync_fence_set_name(fence_fd, name);
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h: In functi on ‘nvhost_syncpt_create_fence_single_ext’:
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h:628:9: err or: implicit declaration of function ‘host1x_sync_create_fence_single’; did you mean ‘nvhost_syncpt_create_ fence_single_ext’? [-Werror=implicit-function-declaration]
return host1x_sync_create_fence_single(host, id, thresh,
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h: At top le vel:
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h:664:69: er ror: parameter 6 (‘kind’) has incomplete type
enum nvdev_fence_kind kind,
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/include/linux/nvhost.h:659:20: er ror: function declaration isn’t a prototype [-Werror=strict-prototypes]
static inline void nvhost_eventlib_log_fences(struct platform_device *pdev,
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/drivers/crypto/tegra-se-nvhost.c In function ‘tegra_se_channel_submit_gather’:
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/drivers/crypto/tegra-se-nvhost.c: 858:9: error: implicit declaration of function ‘nvhost_channel_map’; did you mean ‘nvhost_channel_unmap’? -Werror=implicit-function-declaration]
err = nvhost_channel_map(pdata, &se_dev->channel, pdata);
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/drivers/crypto/tegra-se-nvhost.c: 865:8: error: implicit declaration of function ‘nvhost_job_alloc’; did you mean ‘host1x_job_alloc’? [-Werro r=implicit-function-declaration]
job = nvhost_job_alloc(se_dev->channel, 1, 0, 0, 1);
host1x_job_alloc
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/drivers/crypto/tegra-se-nvhost.c: 865:6: error: assignment makes pointer from integer without a cast [-Werror=int-conversion]
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/drivers/crypto/tegra-se-nvhost.c: 897:8: error: implicit declaration of function ‘nvhost_job_add_client_gather_address’; did you mean ‘nvhost _job_add_gather’? [-Werror=implicit-function-declaration]
err = nvhost_job_add_client_gather_address(job, num_words,
nvhost_job_add_gather
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/drivers/crypto/tegra-se-nvhost.c: 904:8: error: implicit declaration of function ‘nvhost_channel_submit’; did you mean ‘nvhost_channel_abort’ ? [-Werror=implicit-function-declaration]
err = nvhost_channel_submit(job);
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/drivers/crypto/tegra-se-nvhost.c: 934:9: error: implicit declaration of function ‘nvhost_intr_register_fast_notifier’; did you mean ‘nvhost_i ntr_register_notifier’? [-Werror=implicit-function-declaration]
err = nvhost_intr_register_fast_notifier(
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/drivers/crypto/tegra-se-nvhost.c: 979:2: error: implicit declaration of function ‘nvhost_job_put’; did you mean ‘nvhost_job_pin’? [-Werror=im plicit-function-declaration]
nvhost_job_put(job);
nvhost_job_pin
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/drivers/crypto/tegra-se-nvhost.c: 982:2: error: implicit declaration of function ‘nvhost_module_idle’; did you mean ‘nvhost_module_do_idle’? [-Werror=implicit-function-declaration]
nvhost_module_idle(se_dev->pdev);
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/drivers/crypto/tegra-se-nvhost.c In function ‘tegra_se_nvhost_prepare_poweroff’:
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/drivers/crypto/tegra-se-nvhost.c: 4078:3: error: implicit declaration of function ‘nvhost_putchannel’; did you mean ‘nvhost_getchannel’? [-We rror=implicit-function-declaration]
nvhost_putchannel(se_dev->channel, 1);
nvhost_getchannel
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/drivers/crypto/tegra-se-nvhost.c In function ‘tegra_se_probe’:
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/drivers/crypto/tegra-se-nvhost.c: 4246:8: error: implicit declaration of function ‘nvhost_client_device_get_resources’; did you mean ‘nvhost_ client_request_firmware’? [-Werror=implicit-function-declaration]
err = nvhost_client_device_get_resources(pdev);
nvhost_client_request_firmware
CC drivers/extcon/extcon-gpio.o
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/drivers/crypto/tegra-se-nvhost.c: 4254:8: error: implicit declaration of function ‘nvhost_module_init’; did you mean ‘nvhost_module_busy’? [- Werror=implicit-function-declaration]
err = nvhost_module_init(pdev);
nvhost_module_busy
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/drivers/crypto/tegra-se-nvhost.c: 4261:8: error: implicit declaration of function ‘nvhost_client_device_init’; did you mean ‘host1x_device_in it’? [-Werror=implicit-function-declaration]
err = nvhost_client_device_init(pdev);
host1x_device_init
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/drivers/crypto/tegra-se-nvhost.c In function ‘tegra_se_remove’:
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/drivers/crypto/tegra-se-nvhost.c: 4552:2: error: implicit declaration of function ‘nvhost_client_device_release’; did you mean ‘nvhost_channe l_release’? [-Werror=implicit-function-declaration]
nvhost_client_device_release(pdev);
nvhost_channel_release
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/drivers/crypto/tegra-se-nvhost.c At top level:
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/nvidia/drivers/crypto/tegra-se-nvhost.c: 4565:10: error: ‘nvhost_module_pm_ops’ undeclared here (not in a function); did you mean ‘nvhost_module_pow ered’?
.pm = &nvhost_module_pm_ops,
nvhost_module_powered
cc1: all warnings being treated as errors
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/kernel-4.9/scripts/Makefile.build:335: r ecipe for target ‘drivers/crypto/tegra-se-nvhost.o’ failed
make[3]: *** [drivers/crypto/tegra-se-nvhost.o] Error 1
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/kernel-4.9/scripts/Makefile.build:649: r ecipe for target ‘drivers/crypto’ failed
make[2]: *** [drivers/crypto] Error 2
make[2]: *** Waiting for unfinished jobs…
CC drivers/extcon/extcon-gpio-states.o
CC drivers/extcon/extcon-usb-gpio.o
CC drivers/dma-buf/reservation.o
CC drivers/extcon/extcon-disp-state.o
LD drivers/extcon/extcon-core.o
CC drivers/dma-buf/seqno-fence.o
CC drivers/dma-buf/fence-array.o
CC drivers/dma-buf/sync_file.o
LD drivers/extcon/built-in.o
LD drivers/dma-buf/built-in.o
/home/ubuntu64/Workspace/JetsonNano/Linux_for_Tegra/sources/kernel/kernel-4.9/Makefile:1104: recipe for tar get ‘drivers’ failed
make[1]: *** [drivers] Error 2
make[1]: Leaving directory ‘/home/ubuntu64/Workspace/JetsonNano/kernel_out’
Makefile:171: recipe for target ‘sub-make’ failed
make: *** [sub-make] Error 2
I’ll be very thankful if anybody could know sth, plz tell me.
- The dsi panel initialization does not need to rebuild TEGRA DRM driver. Instead, you need to enable it through device tree.
Please refer to the device tree of tx1 -> hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-cv-base-p2597-2180-a00.dts
In this file, it indicates what you need as below.
269 dc@54200000 {
270 status = "okay";
271 nvidia,dc-flags = <TEGRA_DC_FLAG_ENABLED>;
272 nvidia,emc-clk-rate = <300000000>;
273 nvidia,fb-bpp = <32>; /* bits per pixel */
274 nvidia,fb-flags = <TEGRA_FB_FLIP_ON_PROBE>;
275 nvidia,dc-or-node = "/host1x/dsi";
276 nvidia,dc-connector = <&dsi>;
277 win-mask = <0x7>; /* Assign only wins A/B/C */
278 };
279
280 /* tegradc.1 */
281 dc@54240000 {
282 status = "okay";
283 nvidia,dc-flags = <TEGRA_DC_FLAG_ENABLED>;
284 nvidia,emc-clk-rate = <300000000>;
285 nvidia,cmu-enable = <1>;
286 nvidia,fb-bpp = <32>; /* bits per pixel */
287 nvidia,fb-flags = <TEGRA_FB_FLIP_ON_PROBE>;
288 nvidia,dc-or-node = "/host1x/sor1";
289 nvidia,dc-connector = <&sor1>;
290 win-mask = <0x7>; /* Assign only wins A/B/C */
291 };
292
293 dsi {
294 nvidia,dsi-controller-vs = <DSI_VS_1>;
295 status = "okay";
296 nvidia,active-panel = <&panel_a_wuxga_8_0>;
297 panel-a-wuxga-8-0 {
298 status = "okay";
299 nvidia,dsi-dpd-pads = <DSIC_DPD_EN DSID_DPD_EN>;
300 nvidia,panel-rst-gpio = <&gpio TEGRA_GPIO(V, 2) 0>; /* PV2 */
301 nvidia,panel-bl-pwm-gpio = <&gpio TEGRA_GPIO(V, 0) 0>; /* PV0 */
302 disp-default-out {
303 nvidia,out-flags = <TEGRA_DC_OUT_CONTINUOUS_MODE>;
304 };
305 };
306 };
- Your command to build driver is not correct, please refer to L4T documentation from our download center.
