Mirror showing the caustic generated by another mirror?
Greetings and congratulations on your great work.
I am using “Cast Mesh Caustics” to reflect light through several small mirrors. This works well. But I also have a large mirror that is not part of that set of mirrors, but it should show the caustics generated by those tiny mirrors. Is this even possible? ChatGPT says it’s an unsurmountable technical limitation. Is this true? What can I do? I’m using 5.4.4
Thank you :)
