Hi, there seems to be a problem with my newly installed Isaac Sim 2022.1.1… I can’t acces the user_examples or the Hello World example anymore. Here are the only examples I can open : Import Robots, Sensors, ROS and Demos
How can I fix this issue?
Thank you,
Samuel
Hi @samuel.blanchet.2
Have you been able to solve the problem?
You can always check if the extension is enabled as shown in the image.
In case it cannot be enabled, most probably there is some error in the code that does not allow to start the extension. Have you noticed any errors in the terminal? Can you share the logs?
Thank you @toni.sm for helping the other users.
@samuel.blanchet.2, were you able to access the examples?
