If enabling the extension is not working or it is not possible you can always delete the current extension folder and replace it with the original version 😅
This has been solved by editing the hello_wolrd.py!
I don’t know why but found the file path from extension’s “ISAAC SIM EXAMPLES”
And then check the file ‘hellow_world.py’ fix code correctly.
after that Extension has work and Examples are revealed
