Missing Object ID information from RTX Lidar Omnigraph node RtxSensorCpuIsaacReadRTXLidarData
Isaac Sim Version
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: NVIDIA RTX A3000 Laptop GPU
  • Driver Version: 535.161.08
  • CUDA Version: 12.2
Topic Description
Object Id information from the annotator, RtxSensorCpuIsaacReadRTXLidarData, is not getting filled.
Detailed Description
I am simulating Ouster-0 128x1024 @10Hz sensor in isaac sim by first creating the sensor, creating render product and attaching the annotator RtxSensorCpuIsaacReadRTXLidarData as shown in the code below.
The reason I am not using RtxSensorCpuIsaacCreateRTXLidarScanBuffer is that, scan buffer has it’s own issues (data from previous frames not getting cleared, deltaTimes for each point not being in proper time units and channel Ids not being available, see this issue).
Information quality from RtxSensorCpuIsaacReadRTXLidarData is so much better and up to date compared to RtxSensorCpuIsaacCreateRTXLidarScanBuffer. So, I in the end ended up creating a new Omni node that stitches multiple sectors of data from RtxSensorCpuIsaacReadRTXLidarData which outputs into ROS with the point format that Ouster Driver outputs at the frequency of the sensor (10hz) instead of every render frame as ROS1RTXLidarHelper does. The node I created also has the feature to set phase-lock (internal to Ouster) to be more realistic. Long story short, switching to RtxSensorCpuIsaacCreateRTXLidarScanBuffer is not an option.
All the information, X, Y, Z, I, T, Channel is accurate from the node RtxSensorCpuIsaacReadRTXLidarData except for ObjectId. when I use the following code regardless of how many objects I have in the scene I only see ‘0’.
import omni
import omni.graph.core as og
from isaacsim.core.utils.extensions import enable_extension
from pxr import Gf
import omni.timeline
import numpy as np
lidar_config = "OS0_REV7_128ch10hz1024res"
_, sensor0 = omni.kit.commands.execute(
    "IsaacSensorCreateRtxLidar",
    path=f"/sensor0",
    parent=None,
    config=lidar_config,
    translation=(1, 0, 1.0),
    orientation=Gf.Quatd(1.0, 0.0, 0.0, 0.0),  # Gf.Quatd is w,i,j,k
rp = rep.create.render_product(sensor0.GetPath(), [1, 1], name=f"Isaac0")
read_lidar_pointcloud = rep.AnnotatorRegistry.get_annotator("RtxSensorCpuIsaacReadRTXLidarData")
read_lidar_pointcloud.initialize(keepOnlyPositiveDistance=False)
read_lidar_pointcloud.attach(rp)
frame_count = 0
def on_timeline_event(event: omni.timeline.TimelineEventType):
    global frame_count
    if event.type == omni.timeline.TimelineEventType.CURRENT_TIME_TICKED.value:
        oids = read_lidar_pointcloud.get_data()["objectIds"]
        unique_oids = np.unique(oids)
        print(f"Object Count: {len(unique_oids)}, Object Ids: {unique_oids}")
        frame_count += 1
        if frame_count >= 20:
           timeline_sub.unsubscribe()
timeline = omni.timeline.get_timeline_interface()
timeline_sub = timeline.get_timeline_event_stream().create_subscription_to_pop(on_timeline_event)
Steps to Reproduce
  1. Open any USD or create a scene with ground plane, physics scene, cone, cube, sphere
  2. Open Script Editor and paste the above code.
  3. Run the simulation and you will see ‘0’
Error Messages
Screenshots or Videos
Additional Information
What I’ve Tried
I checked to see whether Object Id data from RtxSensorCpuIsaacCreateRTXLidarScanBuffer is good or not and it is not. Object Id information from RtxSensorCpuIsaacCreateRTXLidarScanBuffer starts from 0 and increases to infinity.
Related Issues
Additional Context
None
Hi @naga4 please try adding --/app/sensors/nv/lidar/auxDataOutput=FULL when you start Isaac Sim. For example./isaac-sim.sh --/app/sensors/nv/lidar/auxDataOutput=FULL
Object ID is part of the auxiliary data portion of the GenericModelOutput structure, and the fields actually provided in the auxiliary data are governed by that setting; possible values are NONE, BASIC, EXTRA (default), and FULL.
That did not help.
This is how I launched the sim,
isaac-sim.sh --/isaac/startup/ros_bridge_extension=isaacsim.ros1.bridge --/rtx/ecoMode/enabled=True --/app/sensors/nv/lidar/auxDataOutput=FULL
After adding lidar, using the code attached in the description and adding 2 obejcts in the scene (1 cube and 1 cylinder of type MESH), I am still seeing ‘0’ in object ids, same as before.
I also tried changing this setting to FULL by going to /isaac_sim/exts/isaacsim.sensors.rtx/config/extension.toml and setting app.sensors.nv.lidar.auxDataOutput to FULL. This didn’t work either.
Scene
