Any reason for DPDK-mlx5 driver returning incorrect speed-capability. Reports 40G when NIC is easily capable of 100G with other end connected to a 100G link. rte_eth_dev_info_get is returning incorrect struct rte_eth_dev_info–>speed_capa (40G). When links come up they do come up as 100G which is more than 40G. rte function to return the link speed (rte_eth_link_get) also returns 100G but speed_capa is still falling off (40G). Can you please provide a patch to fix this or provide any initialization setting during rte_eth_dev_register or other calls that fixes this?
lspci-output:
65:00.4 Ethernet controller: Mellanox Technologies ConnectX Family mlx5Gen Virtual Function
Subsystem: Mellanox Technologies ConnectX Family mlx5Gen Virtual Function
Control: I/O- Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
NUMA node: 0
Region 0: Memory at 240004200000 (64-bit, prefetchable) [virtual] [size=1M]
Capabilities: [60] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop- FLReset-
MaxPayload 128 bytes, MaxReadReq 128 bytes
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 16GT/s, Width x16, ASPM not supported
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed unknown (downgraded), Width x0 (downgraded)
TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABC, TimeoutDis+, NROPrPrP-, LTR-
10BitTagComp+, 10BitTagReq-, OBFF Not Supported, ExtFmt-, EETLPPrefix-
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS-, TPHComp-, ExtTPHComp-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
AtomicOpsCtl: ReqEn-
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [9c] MSI-X: Enable+ Count=12 Masked-
Vector table: BAR=0 offset=00002000
PBA: BAR=0 offset=00003000
Capabilities: [100 v1] Vendor Specific Information: ID=0000 Rev=0 Len=00c <?>
Capabilities: [150 v1] Alternative Routing-ID Interpretation (ARI)
ARICap: MFVC- ACS-, Next Function: 0
ARICtl: MFVC- ACS-, Function Group: 0
Kernel driver in use: mlx5_core
Kernel modules: mlx5_core
bash-4.4$ lsb_release -a
LSB Version: :core-4.1-amd64:core-4.1-ia32:core-4.1-noarch
Distributor ID: OracleServer
Description: Oracle Linux Server release 8.8
Release: 8.8
Codename: n/a
bash-4.4$
ethtool output:
r750-1:~/cloudy-saos$ ethtool ens1f1np1
Settings for ens1f1np1:
Supported ports: [ FIBRE ]
Supported link modes: 1000baseT/Full
1000baseKX/Full
10000baseT/Full
10000baseKR/Full
10000baseR_FEC
40000baseKR4/Full
40000baseCR4/Full
40000baseSR4/Full
40000baseLR4/Full
25000baseCR/Full
25000baseKR/Full
25000baseSR/Full
50000baseCR2/Full
50000baseKR2/Full
100000baseKR4/Full
100000baseSR4/Full
100000baseCR4/Full
100000baseLR4_ER4/Full
50000baseSR2/Full
1000baseX/Full
10000baseCR/Full
10000baseSR/Full
10000baseLR/Full
10000baseER/Full
50000baseKR/Full
50000baseSR/Full
50000baseCR/Full
50000baseLR_ER_FR/Full
50000baseDR/Full
100000baseKR2/Full
100000baseSR2/Full
100000baseCR2/Full
100000baseLR2_ER2_FR2/Full
100000baseDR2/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: Yes
Supported FEC modes: None BaseR RS
Advertised link modes: 1000baseT/Full
1000baseKX/Full
10000baseT/Full
10000baseKR/Full
10000baseR_FEC
40000baseKR4/Full
40000baseCR4/Full
40000baseSR4/Full
40000baseLR4/Full
25000baseCR/Full
25000baseKR/Full
25000baseSR/Full
50000baseCR2/Full
50000baseKR2/Full
100000baseKR4/Full
100000baseSR4/Full
100000baseCR4/Full
50000baseSR2/Full
1000baseX/Full
10000baseCR/Full
10000baseSR/Full
10000baseLR/Full
10000baseER/Full
50000baseKR/Full
50000baseSR/Full
50000baseCR/Full
50000baseDR/Full
100000baseKR2/Full
100000baseSR2/Full
100000baseCR2/Full
100000baseDR2/Full
Advertised pause frame use: Symmetric
Advertised auto-negotiation: Yes
Advertised FEC modes: None
Speed: 100000Mb/s
Duplex: Full
Port: FIBRE
PHYAD: 0
Transceiver: internal
Auto-negotiation: on
Cannot get wake-on-lan settings: Operation not permitted
Current message level: 0x00000004 (4)
link
Link detected: yes
Few DPDK functions traversed:
rte_eth_dev_info_get()->mlx5_dev_infos_get()->
info->speed_capa = priv->link_speed_capa;
Do see supported/advertised link-modes in ethtool output (pasted above) showing corresponding100G below in the driver logic, assuming I am looking at the right file that picks speed_capa
DPDK Mlx5 driver code-snippets
542 if (sc & (MLX5_BITSHIFT(ETHTOOL_LINK_MODE_40000baseKR4_Full_BIT) |
543 MLX5_BITSHIFT(ETHTOOL_LINK_MODE_40000baseCR4_Full_BIT) |
544 MLX5_BITSHIFT(ETHTOOL_LINK_MODE_40000baseSR4_Full_BIT) |
545 MLX5_BITSHIFT(ETHTOOL_LINK_MODE_40000baseLR4_Full_BIT)))
546 priv->link_speed_capa |= ETH_LINK_SPEED_40G;
Versus
559 if (sc & (MLX5_BITSHIFT(ETHTOOL_LINK_MODE_100000baseKR4_Full_BIT) |
560 MLX5_BITSHIFT(ETHTOOL_LINK_MODE_100000baseSR4_Full_BIT) |
561 MLX5_BITSHIFT(ETHTOOL_LINK_MODE_100000baseCR4_Full_BIT) |
562 MLX5_BITSHIFT(ETHTOOL_LINK_MODE_100000baseLR4_ER4_Full_BIT)))
563 priv->link_speed_capa |= ETH_LINK_SPEED_100G;
Please let me know if you need additional information. Thanks
