Description
Hey there, I am currently trying to get a object detection & instance segmentation algorithm from MMDetection running on my Jetson AGX Xavier. For setting up the environment, I am following the procedure here: Prerequisites — MMDetection 2.20.0 documentation
I have created a new conda environment and I am trying to install pytorch on it. (conda install pytorch torchvision cudatoolkit=10.2 -c pytorch) but this keeps throwing me the following error:
PackagesNotFoundError: The following packages are not available from current channels:
- torchvision=0.4.2
- cudatoolkit=9.2
- pytorch=1.3.1
I am able to install pytorch using pip (pip3 install torch torchvision). However, I cannot access cuda from it as is throws False if I type import torch → torch.cuda.is_available().
Has anyone encountered these issues on a Jetson and do you know a way to solve this issue?
Furthermore, from searching for this on the Web I am doubting if MMDetection is really suited for the Jetson. I am reading a lot about using ONNX to convert the model to TensorRT. I would be very happy if someone could give me some advice on how to proceed with this!
Thanks a lot and best regards,
Joël
Environment
TensorRT Version: 8.2.1
CUDA Version: 10.2
