I’m writing this in order to solve an issue with Open vSwitch with DPDK. I can’t install OVS in my Nvidia JETSON ARX ORIN. I’ve tried to install OVS following the steps in Open vSwitch with DPDK — Open vSwitch 3.5.90 documentation
that are:
· sudo wget https://fast.dpdk.org/rel/dpdk-23.11.3.tar.xz
· sudo tar xf dpdk-23.11.3.tar.xz
· export DPDK_DIR=/usr/src/dpdk-stable-23.11.3
· sudo meson build
· sudo ninja -C build
· sudo ninja -C build install
· sudo ldconfig
· ./configure --with-dpdk=static
· export PATH=$PATH:/usr/local/share/openvswitch/scripts
· sudo ovsdb-tool create /usr/local/etc/openvswitch/conf.db /usr/local/share/openvswitch/vswitch.ovsschema
· sudo mkdir -p /usr/local/var/run/openvswitch
· sudo mkdir -p /usr/local/etc/openvswitch
export PATH=$PATH:/usr/local/share/openvswitch/scripts $ export DB_SOCK=/usr/local/var/run/openvswitch/db.sock $ ovs-vsctl --no-wait set Open_vSwitch . other_config:dpdk-init=true
Finally, when I run “ovs-ctl --no-ovsdb-server --db-sock=”$DB_SOCK" start", where export DB_SOCK=/usr/local/var/run/openvswitch/db.sock, the output is: modprobe: FATAL: Module openvswitch not found in directory /lib/modules/5.15.148-tegra
Inserting openvswitch module
not removing bridge module because bridges exist (docker0 l4tbr0 virbr0)
My question is, how can I solve this? OVS can’t run on Nvidia Jetson well?
