MODULE_SHDN_N signal in SW shutdown situation
hello, nvidia teams.
We use a Jetson AGX ORIN(64GB) with custom board L4T 35.5.0.
May I know the normal oscilloscope waveform of MODULE_SHDN_N signal in S/W shutdown situation?
Even if I looked at the documents including the design guide, I could not find out the normal waveform.
I would like to compare it with the oscilloscope waveform that can be found on our custom board.
Thank you.
Please refer to below info in DG.
Module Shutdown Request. Used to inform carrier board that a shutdown request has occurred on-module (either software shutdown via SoC, or thermal shutdown).
