ModuleNotFoundError: No module named 'torch' when launching Isaac Sim
Hi everyone,
I’ve been running into an issue lately with Isaac Sim. Whether I launch it via the Omniverse Launcher or by using ./isaaclab.sh -s (inside or outside my virtual environment isaaclab), I keep getting a bunch of red error messages in the terminal. One of these errors is:
[2,861ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.isaac.universal_robots. Error: No module named 'torch'. Traceback:
  File "/home/user/.local/share/ov/pkg/isaac-sim-4.2.0/kit/kernel/py/omni/ext/_impl/custom_importer.py", line 76, in import_module
    return importlib.import_module(name)
  File "/home/user/.local/share/ov/pkg/isaac-sim-4.2.0/kit/python/lib/python3.10/importlib/__init__.py", line 126, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1050, in _gcd_import
  File "<frozen importlib._bootstrap>", line 1027, in _find_and_load
  File "<frozen importlib._bootstrap>", line 1006, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 688, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 883, in exec_module
  File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
  File "/home/user/.local/share/ov/pkg/isaac-sim-4.2.0/exts/omni.isaac.universal_robots/omni/isaac/universal_robots/__init__.py", line 9, in <module>
    from omni.isaac.universal_robots.kinematics_solver import KinematicsSolver
  File "/home/user/.local/share/ov/pkg/isaac-sim-4.2.0/exts/omni.isaac.universal_robots/omni/isaac/universal_robots/kinematics_solver.py", line 12, in <module>
    from omni.isaac.core.articulations import Articulation
  File "/home/user/.local/share/ov/pkg/isaac-sim-4.2.0/exts/omni.isaac.core/omni/isaac/core/__init__.py", line 11, in <module>
    from omni.isaac.core.physics_context.physics_context import PhysicsContext
  File "/home/user/.local/share/ov/pkg/isaac-sim-4.2.0/exts/omni.isaac.core/omni/isaac/core/physics_context/__init__.py", line 9, in <module>
  File "/home/user/.local/share/ov/pkg/isaac-sim-4.2.0/exts/omni.isaac.core/omni/isaac/core/physics_context/physics_context.py", line 15, in <module>
    from omni.isaac.core.utils.prims import get_prim_at_path, get_prim_path, is_prim_path_valid
  File "/home/user/.local/share/ov/pkg/isaac-sim-4.2.0/exts/omni.isaac.core/omni/isaac/core/utils/prims.py", line 24, in <module>
    from omni.isaac.core.utils.types import SDF_type_to_Gf
  File "/home/user/.local/share/ov/pkg/isaac-sim-4.2.0/exts/omni.isaac.core/omni/isaac/core/utils/types.py", line 12, in <module>
    import torch
The other errors are also about not being able to find the torch module. This is puzzling because I’ve already installed torch in my isaaclab virtual environment, and everything works perfectly when I run my reinforcement learning code there, no issues at all.
I suspect that Isaac Sim might be using its own bundled Python environment instead of the one from my virtual environment. I checked by running ./python.sh from the _isaac_sim folder and tried importing torch, but it wasn’t installed. The Python version in that environment is:
Python 3.10.14 (main, Apr 12 2024, 18:16:13) [GCC 7.3.1 20180303 (Red Hat 7.3.1-5)] on linux
Here’s some more info about my setup:
  • OS: Ubuntu 20.04
  • Isaac Sim version: Installed via Omniverse Launcher (isaac-sim-4.2.0)
  • Virtual environment: Miniconda environment named isaaclab, Python 3.10.15
  • Dependencies: torch and all other required libraries are installed in isaaclab (no issues when running RL code)
  • NVIDIA driver version: 550.120
I’ve also recorded the terminal output when trying to start Isaac Sim, which might be helpful in diagnosing the problem. You can find that information attached in the file start_info.txt (130.5 KB).
I’m really confused about what’s going wrong here and would appreciate any help. If you need more info, I’m happy to provide it.
Thanks in advance!
Have you shared the full log fom launching Isaac Sim via the omniverse Launcher? I think having this information might simplify diagnosing the issue.
I have resolved this issue by reinstalling isaacsim from omniverse launcher.
Regarding python bundled environment i have tried to install pip in that environment using “./python.sh -m ensurepip --upgrade” and installed torch using “./python.sh -m pip install torch torchvision torchaudio” command but no luck! there seem to be some dependencies.
Could you create a new topic for this?
@VickNV Sure, but I don’t have any logs and I’m unable to reproduce the error.
