Hello Dainius,
Thank you for posting your inquiry on the NVIDIA Networking Community.
Based on the information provided, unfortunately you are running a non-supported combination with OL8 and the kernel version you are running.
Based on the RN, we support the following combination:
- Oracle Linux8.2 /w kernel 5.4.17-2011.1.2.el8uek.x86_64
- Oracle Linux8.3 /w kernel 5.4.17-2011.7.4.el8uek.x86_64
When we look in our lab on a system installed with MLNX_OFED 5.4, we see that the proper module is loaded, it does not show a dummy module. See below output from one of our lab systems.
# modinfo cifs
filename: /lib/modules/3.10.0-1160.el7.x86_64/kernel/fs/cifs/cifs.ko.xz
softdep: pre: ccm
softdep: pre: aead2
softdep: pre: sha256
softdep: pre: cmac
softdep: pre: aes
softdep: pre: nls
softdep: pre: md5
softdep: pre: md4
softdep: pre: hmac
softdep: pre: ecb
softdep: pre: des
softdep: pre: arc4
version: 2.10
description: VFS to access servers complying with the SNIA CIFS Specification e.g. Samba and Windows
license: GPL
author: Steve French sfrench@us.ibm.com
alias: fs-cifs
retpoline: Y
rhelversion: 7.9
srcversion: FC201ED8E7403B3F2D0D9F1
depends: dns_resolver
intree: Y
vermagic: 3.10.0-1160.el7.x86_64 SMP mod_unload modversions
signer: CentOS Linux kernel signing key
sig_key: E1:FD:B0:E2:A7:E8:61:A1:D1:CA:80:A2:3D:CF:0D:BA:3A:A4:AD:F5
sig_hashalgo: sha256
parm: CIFSMaxBufSize:Network buffer size (not including header). Default: 16384 Range: 8192 to 130048 (uint)
parm: cifs_min_rcv:Network buffers in pool. Default: 4 Range: 1 to 64 (uint)
parm: cifs_min_small:Small network buffers in pool. Default: 30 Range: 2 to 256 (uint)
parm: cifs_max_pending:Simultaneous requests to server. Default: 32767 Range: 2 to 32767. (uint)
parm: enable_oplocks:Enable or disable oplocks. Default: y/Y/1 (bool)
Thank you and regards,
~NVIDIA Networking Technical Support
