I am trying to compile COSMOMC (a cosmological parameter fitting package) on a cluster of operton machines, running v6 of the Portland compilers and MPICH.
Everything seems to go smoothly until the final link stage (I have used hardcoded paths to be sure that everything is using the compiler and version I expect), when the mpi related functions are not found.
The output from th make file is as follows (camb is a library that is built during the install - I know that this is working, and it does not seem to be related to this problem, in any case).
I would be very grateful for any hints or tips. There is apparently an MPICH library in the appropriate directory.
/usr/local/cluster/pgi/linux86-64/6.0/bin/pgf90 -fast -DMPI -I…/
camb -I/usr/local/cluster/mpi/include -c WMAP_likelihood.f90
camb -I/usr/local/cluster/mpi/include -c utils.F90
camb -I/usr/local/cluster/mpi/include -c settings.f90
camb -I/usr/local/cluster/mpi/include -c cmbtypes.f90
camb -I/usr/local/cluster/mpi/include -c cmbdata.f90
camb -I/usr/local/cluster/mpi/include -c WeakLen.f90
camb -I/usr/local/cluster/mpi/include -c twodf.f90
camb -I/usr/local/cluster/mpi/include -c mpk.f90
camb -I/usr/local/cluster/mpi/include -c supernovae.f90
camb -I/usr/local/cluster/mpi/include -c CMB_Cls_simple.f90
camb -I/usr/local/cluster/mpi/include -c paramdef.F90
camb -I/usr/local/cluster/mpi/include -c propose.f90
camb -I/usr/local/cluster/mpi/include -c params_CMB.f90
camb -I/usr/local/cluster/mpi/include -c calclike.f90
camb -I/usr/local/cluster/mpi/include -c conjgrad_wrapper.f90
camb -I/usr/local/cluster/mpi/include -c EstCovmat.f90
camb -I/usr/local/cluster/mpi/include -c postprocess.f90
camb -I/usr/local/cluster/mpi/include -c MCMC.f90
camb -I/usr/local/cluster/mpi/include -c driver.F90
/usr/local/cluster/pgi/linux86-64/6.0/bin/pgf90 -o …/cosmomc
WMAP_likelihood.o utils.o
settings.o cmbtypes.o cmbdata.o WeakLen.o twodf.o mpk.o supernovae.o
CMB_Cls_simple.o paramdef.o propose.o params_CMB.o calclike.o
conjgrad_wrapper.o
EstCovmat.o postprocess.o MCMC.o driver.o -L…/camb -lcamb -L/usr/
local/cluster/pgi/linux86-64/6.0/lib
-llapack -lblas -L/usr/local/cluster/mpi/lib -lmpich -fast -
DMPI -I…/camb -I/usr/local/cluster/mpi/include
A previously compiled program (“camb”) is made available locally as a
library. That seems to be workig. However, the mpi functions are
still not being seen by the linker;
paramdef.o: In function paramdef_dostop_': paramdef.o(.text+0xf5): undefined reference to mpi_wtime_’
paramdef.o(.text+0x295): undefined reference to mpi_finalize_' paramdef.o: In function paramdef_doabort_‘:
paramdef.o(.text+0x3b2): undefined reference to mpi_abort_' paramdef.o: In function paramdef_addmpiparams_’:
paramdef.o(.text+0x42ba): undefined reference to mpi_wtime_' paramdef.o(.text+0x4496): undefined reference to mpi_isend_’
paramdef.o(.text+0x44ea): undefined reference to mpi_irecv_' paramdef.o(.text+0x4742): undefined reference to mpi_testall_’
paramdef.o(.text+0x47d0): undefined reference to mpi_testall_' paramdef.o(.text+0x48a7): undefined reference to mpi_issend_’
paramdef.o(.text+0x48e6): undefined reference to mpi_iprobe_' paramdef.o(.text+0x4930): undefined reference to mpi_recv_’
paramdef.o(.text+0x552e): undefined reference to mpi_bcast_' paramdef.o(.text+0x558f): undefined reference to mpi_bcast_’
paramdef.o: In function paramdef_checklimitsconverge_': paramdef.o(.text+0x8808): undefined reference to mpi_bcast_’
driver.o: In function MAIN_': driver.o(.text+0x4c): undefined reference to mpi_init_’
driver.o(.text+0x258): undefined reference to mpi_comm_rank_' driver.o(.text+0x2fe): undefined reference to mpi_comm_size_’
driver.o(.text+0x303): undefined reference to `mpi_wtime_’
