I did everything you told me, but now I get this error:
[root@wrf bin]# /opt/pgi/linux86-64/7.1/mpi/mpich/bin/mpif90
/opt/pgi/linux86-64/7.1-6/libso/f90main.o: In function main': f90main.c:(.text+0x3c): undefined reference to MAIN_’
I encountered a similar problem as UdeG but I was unable to solve it.
I installed PGI 7.1-1 and mpich under a 2 x 64bit Opteron running on ubuntu 8.04 and set environment path to /opt/pgi/linux86-64/7.1/mpi/mpich/bin but when I try to compile a simple mpihello.f90 program I get this message:
/usr/bin/ld: cannot find -lmpichf90
I am rather new in Linux. I use PGI 7.1-1 Workstation and I installed the MPICH package which is included in the installation. I have set the environmental variables so PGI works fine. But when I tried to use the mpif90 (path to /opt/pgi/linux86-64/7.1/mpi/mpich/bin) command in a simple program I got that error message. I am trying to run a much more complicated application in parallel mode. As far as the “linking part” you asked me … I did nothing. I downloaded the mpich ubuntu package but it didn’t help either.
