I seem to have run in to an issue similar to what has been described here - NVMe Write Failures on DGX Spark Founders Edition
It started with a kernel-panic mid update.
Now (post few weeks of troubleshooting) the device is not recognising the drive (I may have deleted the boot option from the UEFI menu from the drive at one point during troubleshooting but the understanding is that recovery should have fixed that!)
The os recovery step appears to complete successfully.
Refer screenshot.
The boot options that previously listed the Samsung Drive Option no longer lists it and only the -
a) UEFI - PXE IPv4 Realtek PCIe Controller
b) UEFI - USB - Recovery Drive
Options are listed.
<Note - This is my first post and I am only allowed two screenshots. I could possibly attach it as an answer below if or as required>.
However the Samsung NVMe is listed under NVMe Configurations and also under security tab if secure-boot is disabled (and few other configuration tweaks).
I’ve tried booting a live Ubuntu 24 LTS OS (through recovery USB) and it did not detect the Samsung-NVMe (only SDA - SDA1, SDA2, SDA3 were detected besides few ‘loop’ drives).
The diagnostic for NVMe fails. (Refer screenshot).
Should I consider sending it to OEM support (I am currently on this path) ? Is there anything else I should try ?
