Thank you for kind replay!
I will try watching for GREY color format part.
What I want to do is getting YUV420 multi plannar dmabuff_fd of the Camera buffer, but my v4l2_buf always returns single plane at start_capture.
while (poll(fds, 1, 5000) > 0 && !quit)
if (fds[0].revents & POLLIN) {
struct v4l2_buffer v4l2_buf;
/* Dequeue a camera buff */
memset(&v4l2_buf, 0, sizeof(v4l2_buf));
v4l2_buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
if (ctx->capture_dmabuf)
v4l2_buf.memory = V4L2_MEMORY_DMABUF;
else
v4l2_buf.memory = V4L2_MEMORY_MMAP;
if (ioctl(ctx->cam_fd, VIDIOC_DQBUF, &v4l2_buf) < 0)
ERROR_RETURN("Failed to dequeue camera buff: %s (%d)",
strerror(errno), errno);
ctx->frame++;
/* Save the n-th frame to file */
if (ctx->frame == ctx->save_n_frame)
save_frame_to_file(ctx, &v4l2_buf);
if (ctx->cam_pixfmt == V4L2_PIX_FMT_MJPEG) {
int fd = 0;
uint32_t width, height, pixfmt;
unsigned int i = 0;
unsigned int eos_search_size = MJPEG_EOS_SEARCH_SIZE;
unsigned int bytesused = v4l2_buf.bytesused;
uint8_t *p;
/* v4l2_buf.bytesused may have padding bytes for alignment
Search for EOF to get exact size */
if (eos_search_size > bytesused)
eos_search_size = bytesused;
for (i = 0; i < eos_search_size; i++) {
p =(uint8_t *)(ctx->g_buff[v4l2_buf.index].start + bytesused);
if ((*(p-2) == 0xff) && (*(p-1) == 0xd9)) {
break;
bytesused--;
/* Decoding MJPEG frame */
if (ctx->jpegdec->decodeToFd(fd, ctx->g_buff[v4l2_buf.index].start,
bytesused, pixfmt, width, height) < 0)
ERROR_RETURN("Cannot decode MJPEG");
/* Convert the decoded buffer to YUV420P */
if (-1 == NvBufferTransform(fd, ctx->render_dmabuf_fd,
&transParams))
ERROR_RETURN("Failed to convert the buffer");
} else {
if (ctx->capture_dmabuf) {
/* Cache sync for VIC operation since the data is from CPU */
NvBufferMemSyncForDevice(ctx->g_buff[v4l2_buf.index].dmabuff_fd, 0,
(void**)&ctx->g_buff[v4l2_buf.index].start);
} else {
/* Copies raw buffer plane contents to an NvBuffer plane */
Raw2NvBuffer(ctx->g_buff[v4l2_buf.index].start, 0,
ctx->cam_w, ctx->cam_h, ctx->g_buff[v4l2_buf.index].dmabuff_fd);
/* Convert the camera buffer from YUV422 to YUV420P */
if (-1 == NvBufferTransform(ctx->g_buff[v4l2_buf.index].dmabuff_fd, ctx->render_dmabuf_fd,
&transParams))
if (ctx->cam_pixfmt == V4L2_PIX_FMT_GREY) {
if(!nvbuff_do_clearchroma(ctx->render_dmabuf_fd))
ERROR_RETURN("Failed to clear chroma");
cuda_postprocess(ctx, ctx->render_dmabuf_fd);
/* Preview */
ctx->renderer->render(ctx->render_dmabuf_fd);
/* Enqueue camera buffer back to driver */
if (ioctl(ctx->cam_fd, VIDIOC_QBUF, &v4l2_buf))
ERROR_RETURN("Failed to queue camera buffers: %s (%d)",
I’m watching for this URL which looks like the sample code for getting multi plannar from camera.
https://www.kernel.org/doc/html/latest/userspace-api/media/v4l/dmabuf.html#example-3-6-queueing-dmabuf-using-multi-plane-api
But my program says
Failed to query buff: Invalid argument (22)
I changed
rb.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
to
rb.type = V4L2_BUF_TYPE_VIDEO_CAPTURE_MPLANE;
at request_camera_buff.
static bool
request_camera_buff(context_t *ctx)
/* Request camera v4l2 buffer */
struct v4l2_requestbuffers rb;
memset(&rb, 0, sizeof(rb));
rb.count = V4L2_BUFFERS_NUM;
rb.memory = V4L2_MEMORY_DMABUF;
if (ioctl(ctx->cam_fd, VIDIOC_REQBUFS, &rb) < 0)
ERROR_RETURN("Failed to request v4l2 buffers: %s (%d)",
if (rb.count != V4L2_BUFFERS_NUM)
ERROR_RETURN("V4l2 buffer number is not as desired");
for (unsigned int index = 0; index < V4L2_BUFFERS_NUM; index++)
struct v4l2_buffer buf;
/* Query camera v4l2 buf length */
memset(&buf, 0, sizeof buf);
buf.index = index;
if (ioctl(ctx->cam_fd, VIDIOC_QUERYBUF, &buf) < 0)
ERROR_RETURN("Failed to query buff: %s (%d)",
/* TODO: add support for multi-planer
Enqueue empty v4l2 buff into camera capture plane */
buf.m.fd = (unsigned long)ctx->g_buff[index].dmabuff_fd;
if (buf.length != ctx->g_buff[index].size)
WARN("Camera v4l2 buf length is not expected");
ctx->g_buff[index].size = buf.length;
if (ioctl(ctx->cam_fd, VIDIOC_QBUF, &buf) < 0)
ERROR_RETURN("Failed to enqueue buffers: %s (%d)",
return true;
