Hi There,
Is it possible to obtain the source code for the CUDA ‘stereoDisparity_kernel.cu’ distributed with CUDA 10.2 and jetson_multimedia_api ?
Thanks,
Rusty
CUDA and jetson_multimedia_api samples are in the directory:
/usr/local/cuda-10.2/samples/3_Imaging
/usr/src/jetson_multimedia_api
Do you find stereoDisparity_kernel.cu’ with the distribution?
There is CUDA code in
/usr/local/cuda-10.2/samples/3_Imaging/stereoDisparity/stereoDisparity_kernel.cuh
Not sure if it is what you would like to check.
It isn’t stereoDisparity_kernel.cu .
stereoDisparity_kernel.cu is private. Please use functions defined in header files.
Thank you for finally answering the question I had asked. If I could use the library, as is, I would not have requested the source code.
Might I respectfully suggest that you read questions more carefully, in the future.
-Rusty
