Multiple display(Monitor 1(GUI 1) and Monitor 2(GUI 2)) on Xavier NX
Hi Team,
We are using Xavier NX in our custom design and using DP port functionality of it.
I have query related to multiple display :
Xavier NX has capability for multiple display, means if we connect two monitors with DP port then we can open different GUIs on both monitor.
As per my understanding mirroring support is there, same GUI on multiple screen ?
And last
how to achieve same(different gui on multiple screen), any command-line configuration required ?
You may need to define “different GUI” first. The actual case is much more complicated than this description.
For example, if I open youtube website on monitor 2 and keep monitor 1 to stay on ubuntu desktop, is such case also included in your “different GUI” coverage?
We support mirror ubuntu desktop but it does not mean the two monitor will show 100% same content.
HI,
Yes, we required like that
Basically differnet application on different monitor, for ex. camera stream on monitor 2 and some other application on monitor 1.
thanks
Yes, the display framework supports such case.
Any specific settings/configuration are required to achieve it ?
I think you could firstly clarify what is the exact usecase you are trying to do.
As I said in previous comment, even using mouse to click the Chromium browser on your screen can achieve your goal.
In that case, nothing needs to be configured. Just use mouse to click on the application icon.
Thanks for your support and information.
Now, We are clear about it.
