Does ‘4x 1080p’ means that it can process four 1080 videos in parallel at once?
If the above questions are correct,
How should I use gstreamer to do multi-encoding / decoding in parallel?
’ tegrastats ’ command only knows the current frequency of the hw encoder, not the percentage.
Is there any other way to confirm that we are doing multi-encoding?
It looks to be for running encoding on multiple CPU cores. We have independent hardware engines for encoding and decoding, so this is not supported.
