Multiple objects are detected using peoplenet
• Hardware Platform (Jetson / GPU) RTX4080
• DeepStream Version 7.0
My application used deepstream-imagedata-multistream.
The config file is as follows.
# SPDX-FileCopyrightText: Copyright (c) 2022-2024 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# SPDX-License-Identifier: Apache-2.0
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
#tlt-model-key=tlt_encode
onnx-file=../../../../samples/models/tao_pretrained_models/peopleNet/resnet34_peoplenet_int8.onnx
labelfile-path=../../../../samples/configs/tao_pretrained_models/labels_peoplenet.txt
model-engine-file=../../../../samples/models/tao_pretrained_models/peopleNet/resnet34_peoplenet_int8.onnx_b12_gpu0_int8.engine
int8-calib-file=../../../../samples/models/tao_pretrained_models/peopleNet/resnet34_peoplenet_int8.txt
input-dims=3;544;960;0
uff-input-blob-name=input_1
batch-size=12
process-mode=1
model-color-format=0
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=1
num-detected-classes=1
cluster-mode=1
interval=0
gie-unique-id=1
output-blob-names=output_bbox/BiasAdd;output_cov/Sigmoid
#Use the config params below for dbscan clustering mode
#[class-attrs-all]
#detected-min-w=4
#detected-min-h=4
#minBoxes=3
#eps=0.7
#Use the config params below for NMS clustering mode
[class-attrs-all]
topk=20
nms-iou-threshold=0.5
pre-cluster-threshold=0.2
## Per class configurations
[class-attrs-0]
topk=20
pre-cluster-threshold=0.4
#[class-attrs-1]
#pre-cluster-threshold=0.05
#eps=0.7
#dbscan-min-score=0.5
Why I have multiple detections at same person?
Screenshot from 2024-08-22 15-24-09
without any modification of code and cfg, will the issue persist?
I don’t change that pgie part.
I just update at tiler_probe. My modification shouldn’t affect pgie.
I’ll confirm with the original code on Monday. In the meantime, if you have idea, pls suggest me.
please try cluster-mode=2.
