Hi there,
I’m testing the somatic pipeline, both tumor only and tumor-normal pair. While the tumor only gave me results, the tumor-normal pair returned me a vcf that contain only the header.
There’s something I could do?
Thanks in advice.
Hi there,
Thanks in advice.
Hi Stefano,
can you please provide the command line you are using?
This happens when sample or read group ID is the same for normal and tumor bam
Best
Myrieme
Hi Myrieme,
Ok first I used the somatic pipeline command line:
time ./parabricks_install/parabricks/pbrun somatic
–ref /hpcshare/genomics/references/gatk_bundle/reference/resources_broad_hg38_v0_Homo_sapiens_assembly38.fasta
–in-tumor-fq /hpcshare/smarangoni/pbrun_file_io/PD_twins/SG_PD-7107_B/PD-7107_S4_R1_001.fastq.gz /hpcshare/smarangoni/pbrun_file_io/PD_twins/SG_PD-7107_B/PD-7107_S4_R2_001.fastq.gz
–knownSites /hpcshare/genomics/references/gatk_bundle/resources/resources_broad_hg38_v0_hapmap_3.3.hg38.vcf.gz
–out-tumor-bam /hpcshare/smarangoni/pbrun_file_io/PD_twins/PD-7107_B.bam
–out-vcf /hpcshare/smarangoni/pbrun_file_io/PD_twins/PD-7107.vcf
–out-tumor-recal-file /hpcshare/smarangoni/pbrun_file_io/PD_twins/PD-7107_B_recal.txt
–in-normal-fq /hpcshare/smarangoni/pbrun_file_io/PD_twins/SG_PD-7107_P/PD-7108_S6_R1_001.fastq.gz /hpcshare/smarangoni/pbrun_file_io/PD_twins/SG_PD-7107_P/PD-7108_S6_R2_001.fastq.gz
–out-normal-bam /hpcshare/smarangoni/pbrun_file_io/PD_twins/PD-7107_P.bam
–out-normal-recal-file /hpcshare/smarangoni/pbrun_file_io/PD_twins/PD-7107_P_recal.txt
Then I also used the mutectcaller tool using this command line:
time ./parabricks_install/parabricks/pbrun mutectcaller
–in-normal-bam /hpcshare/smarangoni/pbrun_file_io/PD_twins/PD-7107_P.bam
–in-normal-recal-file /hpcshare/smarangoni/pbrun_file_io/PD_twins/PD-7107_P_recal.txt
–normal-name normal
–tumor-name tumor
–in-tumor-bam /hpcshare/smarangoni/pbrun_file_io/PD_twins/PD-7107_B.bam
–in-tumor-recal-file /hpcshare/smarangoni/pbrun_file_io/PD_twins/PD-7107_B_recal.txt.
