Hey all,
I am trying to run Parabricks Deepsomatic with the full command below:
pbrun deepsomatic \
–-mode=ont \
–-ref=%(profile_genome_fa)s \
--in-normal-bam=%(normal_bam)s \
-–in-tumor-bam=%(tumor_bam)s \
--out-variants=%(output_dir)s/%(sample_name)s_deepsomatic.vcf.gz
But I keep getting the Invalid tumor sample name input, exiting. error, the full log is below:
[PB Info 2026-Feb-13 13:18:27] ------------------------------------------------------------------------------
[PB Info 2026-Feb-13 13:18:27] || Parabricks accelerated Genomics Pipeline ||
[PB Info 2026-Feb-13 13:18:27] || Version 4.6.0-1 ||
[PB Info 2026-Feb-13 13:18:27] || deepsomatic ||
[PB Info 2026-Feb-13 13:18:28] Starting DeepSomatic
[PB Info 2026-Feb-13 13:18:28] Running with 2 GPU devices, each with 4 group instances and 6 workers
[PB Error 2026-Feb-13 13:18:28][src2/readers.cpp:1936] Invalid tumor sample name input, exiting.
Process exited with failure. Please check the logs.
For technical support visit
Exiting…
Could not run deepsomatic
Exiting pbrun …
What is causing the error here? What should I need to change/add? I checked the Parabricks Deepsomatic documentation but could not find anything related to the sample name.
Thanks for your help and time!
