My code is working on 6.1.1-devel, But 6.2-devel , 6.3-samples the pipeline is not working
**• Hardware Platform ( GPU )
**• DeepStream Version -----------> 6.3
**• TensorRT Version ---------------> 8.5
**• NVIDIA GPU Driver Version ---------> 535
So when my code works on one version of deepstream(6.1.1-devel) like intended, I am sure there is no problem with my code.
The version upgrade has a problem where something is breaking internally, which I am unable to figure out.
So it will be great if you can help me debug.
The problem with the deepstream-6.3 version is it doesn’t infer parallel, when there are multiple streammux.
Could you attach your whole pipeline and your use case?
Do you want to see the pipeline graph ? or code ? @yuweiw
You can give us a simplified and runnable version of the code and the graph.
Could you suggest any way to share my code and graph with proper privacy. As this is a public forum I can’t able to share my code here … @yuweiw
You can just click on my icon and message to me.
Okey, I will share with you today !
Thanks for your response , @yuweiw
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
You can try to set the sync parameter to 0 and test that.
        filesink.set_property('async', 0)
        filesink.set_property('sync', 0)
