With deepstream_parallel_inference_app in python multiple branch is nor working
**• Hardware Platform (GPU)----. 3070
**• DeepStream Version -------> 6.4
• TensorRT Version ------> 8.6
**• NVIDIA GPU Driver Version (valid for GPU only)---------> 545
This is my previous topic where I explain about from 6.2 onwards parallel branch is not working
Please help me out about this I’m attaching my pipeline image If any element need to change or something Please fill free to advice !!!
The c/c++ sample works. Please make sure your python app is aligned with the sample.
Can you share with me deepstream parallel pipeline picture ? Or Can you check once my pipeline and say to me any element need to change or something I need to change ?
I am trying to understand why It’s not working in 6.2 and above but Working with 6.1.1 … same code no change !
***** PYTHON
If you can share something Where I can find out something new make it done !
You can get the graph by the method described here: DeepStream SDK FAQ - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums
There is some changes from DeepStream 6.1.1 to DeepStream 6.2. Please follow the sample code. NVIDIA-AI-IOT/deepstream_parallel_inference_app: A project demonstrating how to use nvmetamux to run multiple models in parallel. (github.com)
I know how to print the graph But I was getting some error which running So I don’t want to invest time to solve in c++ coz I am using python as a programming language and replicating same kind of pipeline. But If You share that deepstream parallel pipeline with graph, coz you said You ran into it and it was working for you ! It will ease for me to compare both pipeline and debug mine as well.
@Fiona.Chen
Here is the graph I captured . I will delete three days later. play.png - Google Drive
Thanks I downloaded Let me compare both and try to do my best And get back to you ASAP .
Thanks !
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
