I take the P3449-B01-CPU SCH as my reference.
I don’t have the usb hub, and the Carrier Board Config EEPROM is not soldered.
I use the DP0 as the miniDP.
P3449_B01_CPU_D1_2021-0409_FAB_SCH - c.pdf (762.3 KB)
There are my Problem:
- My DP doesn’t work.
- My Ethernet doesn’t work.
I’m a rookie. How could I do NEXT? I hope some one help me. Thanks a lot.
[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-e82258de)
[0000.130] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.138] Power-up reason: pmc por
[0000.141] No Battery Present
[0000.144] pmic max77620 reset reason
[0000.147] pmic max77620 NVERC : 0x40
[0000.151] RamCode = 0
[0000.153] Platform has DDR4 type RAM
[0000.156] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x1112e4
[0000.172] Entering ramdump check
[0000.175] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.188] Sdram initialization is successful
[0000.192] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.204] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.210] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.216] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.259] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.269] BoardID = 3448, SKU = 0x0
[0000.272] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.276] Nano-SD: checking PT table on QSPI …
[0000.281] Read PT from (2:0)
[0000.296] Using BFS PT to query partitions
[0000.302] Loading Tboot-CPU binary
[0000.330] Verifying TBC in OdmNonSecureSBK mode
[0000.340] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.347] Bootloader downloaded successfully.
[0000.351] Downloaded Tboot-CPU binary to 0xa0000258
[0000.356] MAX77620_GPIO5 configured
[0000.359] CPU power rail is up
[0000.362] CPU clock enabled
[0000.366] Performing RAM repair
[0000.369] Updating A64 Warmreset Address to 0xa00002e9
[0000.374] BoardID = 3448, SKU = 0x0
[0000.377] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.381] Nano-SD: checking PT table on QSPI …
[0000.385] Loading NvTbootBootloaderDTB
[0000.452] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.525] Bootloader DTB Load Address: 0x83000000
[0000.530] BoardID = 3448, SKU = 0x0
[0000.533] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.537] Nano-SD: checking PT table on QSPI …
[0000.541] Loading NvTbootKernelDTB
[0000.607] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.680] Kernel DTB Load Address: 0x83100000
[0000.684] BoardID = 3448, SKU = 0x0
[0000.688] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.692] Nano-SD: checking PT table on QSPI …
[0000.698] Loading cboot binary
[0000.814] Verifying EBT in OdmNonSecureSBK mode
[0000.855] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.862] Bootloader downloaded successfully.
[0000.866] BoardID = 3448, SKU = 0x0
[0000.870] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.873] Nano-SD: checking PT table on QSPI …
[0000.878] PT: Partition NCT NOT found !
[0000.882] Warning: Find Partition via PT Failed
[0000.886] Next binary entry address: 0x92c00258
[0000.891] BoardId: 3448
[0000.895] Overriding pmu board id with proc board id
[0000.900] Display board id is not available
[0000.904] BoardID = 3448, SKU = 0x0
[0000.907] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.911] Nano-SD: checking PT table on QSPI …
[0001.016] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.073] /bpmp deleted
[0001.075] SC7EntryFw header found loaded at 0xff700000
[0001.271] OVR2 PMIC
[0001.272] Bpmp FW successfully loaded
[0001.276] BoardID = 3448, SKU = 0x0
[0001.279] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.283] Nano-SD: checking PT table on QSPI …
[0001.288] WB0 init successfully at 0xff780000
[0001.293] Set NvDecSticky Bits
[0001.296] GSC2 address ff53fffc value c0edbbcc
[0001.302] GSC MC Settings done
[0001.305] BoardID = 3448, SKU = 0x0
[0001.309] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.312] Nano-SD: checking PT table on QSPI …
[0001.318] TOS Image length 53680
[0001.321] Monitor size 53680
[0001.324] OS size 0
[0001.339] Secure Os AES-CMAC Verification Success!
[0001.343] TOS image cipher info: plaintext
[0001.347] Loading and Validation of Secure OS Successful
[0001.363] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.368] NvTbootPackSdramParams: start.
[0001.373] NvTbootPackSdramParams: done.
[0001.377] Tegraboot started after 51842 us
[0001.381] Basic modules init took 886466 us
[0001.385] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
[0001.390] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.396] Next stage binary read took 102860 us
[0001.400] Carveout took -126357 us
[0001.403] CPU initialization took 495393 us
[0001.407] Total time taken by TegraBoot 1358362 us
[0001.412] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):5b49e7f80
NOTICE: BL31: Built : 08:37:40, Feb 19 2021
ERROR: Error initializing runtime service trusty_fast
[0001.534] RamCode = 0
[0001.539] LPDDR4 Training: Read DT: Number of tables = 2
[0001.544] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.557] EMC Training Successful
[0001.560] 408000 not found in DVFS table
[0001.566] RamCode = 0
[0001.570] DT Write: emc-table@204000 succeeded
[0001.575] DT Write: emc-table@1600000 succeeded
[0001.579] LPDDR4 Training: Write DT: Number of tables = 2
[0001.626]
[0001.627] Debug Init done
[0001.630] Marked DTB cacheable
[0001.633] Bootloader DTB loaded at 0x83000000
[0001.638] Marked DTB cacheable
[0001.640] Kernel DTB loaded at 0x83100000
[0001.644] DeviceTree Init done
[0001.657] Pinmux applied successfully
[0001.662] gicd_base: 0x50041000
[0001.665] gicc_base: 0x50042000
[0001.668] Interrupts Init done
[0001.672] Using base:0x60005090 & irq:208 for tick-timer
[0001.678] Using base:0x60005098 for delay-timer
[0001.682] platform_init_timer: DONE
[0001.685] Timer(tick) Init done
[0001.689] osc freq = 38400 khz
[0001.693]
[0001.694] Welcome to L4T Cboot
[0001.697]
[0001.698] Cboot Version: 00.00.2018.01-t210-39562017
[0001.703] calling constructors
[0001.706] initializing heap
[0001.709] initializing threads
[0001.712] initializing timers
[0001.715] creating bootstrap completion thread
[0001.719] top of bootstrap2()
[0001.722] CPU: ARM Cortex A57
[0001.725] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.730] initializing platform
[0001.737] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.742] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.746] Macronix QSPI chip present
[0001.750] SPI device register
[0001.752] init boot device
[0001.755] allocating memory for boot device(SPI)
[0001.760] registering boot device
[0001.778] QSPI bdev is already initialized
[0001.782] Enable APE clock
[0001.785] Un-powergate APE partition
[0001.788] of_register: registering tegra_udc to of_hal
[0001.793] of_register: registering inv20628-driver to of_hal
[0001.799] of_register: registering ads1015-driver to of_hal
[0001.804] of_register: registering lp8557-bl-driver to of_hal
[0001.810] of_register: registering bq2419x_charger to of_hal
[0001.816] of_register: registering bq27441_fuel_gauge to of_hal
[0001.827] gpio framework initialized
[0001.831] of_register: registering tca9539_gpio to of_hal
[0001.836] of_register: registering tca9539_gpio to of_hal
[0001.842] of_register: registering i2c_bus_driver to of_hal
[0001.847] of_register: registering i2c_bus_driver to of_hal
[0001.853] of_register: registering i2c_bus_driver to of_hal
[0001.858] pmic framework initialized
[0001.862] of_register: registering max77620_pmic to of_hal
[0001.867] regulator framework initialized
[0001.871] of_register: registering tps65132_bl_driver to of_hal
[0001.877] initializing target
[0001.883] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.891] board ID = D78, board SKU = 0
[0001.895] Skipping Z3!
[0001.899] fixed regulator driver initialized
[0001.917] initializing OF layer
[0001.920] NCK carveout not present
[0001.924] Skipping dts_overrides
[0001.928] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.945] I2C Bus Init done
[0001.947] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.958] I2C Bus Init done
[0001.960] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.971] I2C Bus Init done
[0001.973] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.984] I2C Bus Init done
[0001.987] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.997] I2C Bus Init done
[0002.000] of_children_init: Ops found for compatible string maxim,max77620
[0002.010] max77620_init using irq 118
[0002.015] register ‘maxim,max77620’ pmic
[0002.019] gpio_driver_register: register ‘max77620-gpio’ driver
[0002.025] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.036] I2C Bus Init done
[0002.040] NCK carveout not present
[0002.049] Find /i2c@7000c000’s alias i2c0
[0002.053] get eeprom at 1-a0, size 256, type 0
[0002.062] Find /i2c@7000c500’s alias i2c2
[0002.066] get eeprom at 3-a0, size 256, type 0
[0002.070] get eeprom at 3-ae, size 256, type 0
[0002.075] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.080] I2C slave not started
[0002.083] I2C write failed
[0002.086] Writing offset failed
[0002.089] eeprom_init: EEPROM read failed
[0002.093] pm_ids_update: eeprom init failed
[0002.097] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.127] pm_ids_update: The pm board id is 3448-0000-200
[0002.134] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.142] pm_ids_update: pm id update successful
[0002.147] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.152] I2C slave not started
[0002.155] I2C write failed
[0002.158] Writing offset failed
[0002.161] eeprom_init: EEPROM read failed
[0002.165] pm_ids_update: eeprom init failed
[0002.195] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.200] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.208] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.214] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.222] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e4:16:3e
[0002.229] Plugin Manager: Parse ODM data 0x000a4000
[0002.241] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.256] Find /i2c@7000c000’s alias i2c0
[0002.260] get eeprom at 1-a0, size 256, type 0
[0002.269] Find /i2c@7000c500’s alias i2c2
[0002.273] get eeprom at 3-a0, size 256, type 0
[0002.277] get eeprom at 3-ae, size 256, type 0
[0002.281] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.287] I2C slave not started
[0002.290] I2C write failed
[0002.292] Writing offset failed
[0002.295] eeprom_init: EEPROM read failed
[0002.299] pm_ids_update: eeprom init failed
[0002.304] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.334] pm_ids_update: The pm board id is 3448-0000-200
[0002.340] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.347] pm_ids_update: pm id update successful
[0002.351] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.357] I2C slave not started
[0002.360] I2C write failed
[0002.362] Writing offset failed
[0002.365] eeprom_init: EEPROM read failed
[0002.369] pm_ids_update: eeprom init failed
[0002.399] Add serial number:0421219023994 as DT property
[0002.407] Applying platform configs
[0002.414] platform-init is not present. Skipping
[0002.418] calling apps_init()
[0002.424] Couldn’t find GPT header
[0002.429] Proceeding to Cold Boot
[0002.432] starting app android_boot_app
[0002.436] Device state: unlocked
[0002.439] display console init
[0002.447] could not find regulator
[0002.450] hdmi cable connected
[0002.488] DT entry for leds-pwm not found
[0004.461] I2C transfer timeout
[0004.463] I2C write failed
[0004.466] Writing offset failed
[0004.469] could not read edid
[0004.474] tmds-config node not found
[0004.478] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regulator to 1050000 micro volts
[0004.492] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0004.500] could not find regulator
[0004.503] could not find regulator
[0004.507] could not find regulator
[0004.535] using default cmu settings
[0004.539] dc_hdmi_enable, starting HDMI initialisation
[0004.545] dc_hdmi_enable, HDMI initialisation complete
[0004.550] list and configure display window
[0004.555] display console init completed
[0004.562] subnode volume_up is not found !
[0004.566] subnode back is not found !
[0004.570] subnode volume_down is not found !
[0004.574] subnode menu is not found !
[0004.578] Gpio keyboard init success
[0004.658] found decompressor handler: lz4-legacy
[0004.673] decompressing blob (type 1)…
[0004.739] load_bmp_blob: panelresolution=480 type=0
[0004.814] decompressor handler not found
[0004.818] load_firmware_blob: Firmware blob loaded, entries=2
[0004.824] XUSB blob version 0 size 124416 @ 0x92dee28c
[0004.830] -------> se_aes_verify_sbk_clear: 747
[0004.834] se_aes_verify_sbk_clear: Error
[0004.838] SE operation failed
[0004.841] bl_battery_charging: connected to external power supply
[0004.853] device_query_partition_size: failed to open partition spiflash0:MSC !
[0004.860] MSC Partition not found
[0004.866] device_query_partition_size: failed to open partition spiflash0:USP !
[0004.874] USP partition read failed!
[0004.877] blob_init: blob-partition USP header read failed
[0004.883] android_boot Unable to update recovery partition
[0004.888] kfs_getpartname: name = LNX
[0004.892] Loading kernel from LNX
[0004.901] Found 19 BFS partitions in “spiflash0”
[0005.220] load kernel from storage
[0005.225] decompressor handler not found
[0005.489] Successfully loaded kernel and ramdisk images
[0005.494] board ID = D78, board SKU = 0
[0005.499] sdmmc node status = okay
[0005.502] sdcard instance = 0
[0005.505] sdcard gpio handle 0x5b
[0005.508] sdcard gpio pin 0xc9
[0005.511] sdcard gpio flags 0x0
[0005.514] vmmc-supply 0x9e
[0005.517] cd_gpio_pin = 201
[0005.520] pin_state = 0
[0005.522] Found sdcard
[0005.524] SD-card IS present …
[0005.527] load_and_boot_kernel: SD card detected OK
[0005.533] load_bmp_blob: panelresolution=480 type=0
[0005.607] display bmp image done
[0005.610] NCK carveout not present
[0005.613] Skipping dts_overrides
[0005.616] NCK carveout not present
[0005.626] Find /i2c@7000c000’s alias i2c0
[0005.630] get eeprom at 1-a0, size 256, type 0
[0005.639] Find /i2c@7000c500’s alias i2c2
[0005.643] get eeprom at 3-a0, size 256, type 0
[0005.647] get eeprom at 3-ae, size 256, type 0
[0005.651] pm_ids_update: Updating 1,a0, size 256, type 0
[0005.657] I2C slave not started
[0005.660] I2C write failed
[0005.662] Writing offset failed
[0005.665] eeprom_init: EEPROM read failed
[0005.669] pm_ids_update: eeprom init failed
[0005.673] pm_ids_update: Updating 3,a0, size 256, type 0
[0005.704] pm_ids_update: The pm board id is 3448-0000-200
[0005.710] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0005.719] pm_ids_update: pm id update successful
[0005.723] pm_ids_update: Updating 3,ae, size 256, type 0
[0005.729] I2C slave not started
[0005.732] I2C write failed
[0005.734] Writing offset failed
[0005.737] eeprom_init: EEPROM read failed
[0005.741] pm_ids_update: eeprom init failed
[0005.771] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.777] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0005.785] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.791] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0005.799] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e4:16:3e
[0005.805] Plugin Manager: Parse ODM data 0x000a4000
[0005.818] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0005.826] Add serial number:0421219023994 as DT property
[0005.835] “bpmp” doesn’t exist, creating
[0005.841] Updated bpmp info to DTB
[0005.846] Updated initrd info to DTB
[0005.849] “proc-board” doesn’t exist, creating
[0005.855] Updated board info to DTB
[0005.859] “pmu-board” doesn’t exist, creating
[0005.865] Updated board info to DTB
[0005.868] “display-board” doesn’t exist, creating
[0005.874] Updated board info to DTB
[0005.877] “reset” doesn’t exist, creating
[0005.882] Updated reset info to DTB
[0005.885] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt tegra_fbmem=0x140000@0x92ca9000 is_hdmi_initialised=1
[0005.924] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0005.930] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0005.943] Updated bootarg info to DTB
[0005.947] Adding uuid 000000016441b7441c00000003ff0240 to DT
[0005.953] Adding eks info 0 to DT
[0005.958] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0005.964] Updated memory info to DTB
[0005.972] set vdd_core voltage to 1125 mv
[0005.976] setting ‘vdd-core’ regulator to 1125000 micro volts
[0005.982] Found secure-pmc; disable BPMP
U-Boot 2020.04-g6b630d64fd (Feb 19 2021 - 08:37:46 -0800)
SoC: tegra210
Model: NVIDIA Jetson Nano Developer Kit
Board: NVIDIA P3450-0000
DRAM: 4 GiB
MMC: sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from SPI Flash… SF: Detected mx25u3235f with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
845 bytes read in 26 ms (31.3 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
7159841 bytes read in 328 ms (20.8 MiB/s)
Retrieving file: /boot/Image
34338824 bytes read in 1502 ms (21.8 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt tegra_fbmem=0x140000@0x92ca9000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
ERROR: reserving fdt memory region failed (addr=0 size=0)
Using Device Tree in place at 0000000083100000, end 000000008317e68d
copying carveout for /host1x@50000000/dc@54200000…
copying carveout for /host1x@50000000/dc@54240000…
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (buildbrain@mobile-u64-5294-d8000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Fri Feb 19 08:40:32 PST 2021
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00140000@92ca9000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 1.314705] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.322383] imx219 6-0010: board setup failed
[ 11.126021] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 11.132502] tegra-i2c 7000c700.i2c: — register dump for debugging ----
[ 11.139205] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 11.144342] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 11.151061] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 11.156634] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 11.162464] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 11.167712] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 11.173051] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 11.180841] tegradc tegradc.1: dpd enable lookup fail:-19
[ 11.943381] cgroup: cgroup2: unknown option “nsdelegate”
[ 13.546374] random: crng init done
[ 13.549778] random: 7 urandom warning(s) missed due to ratelimiting
[ 13.580064] using random self ethernet address
[ 13.585555] using random host ethernet address
[ 21.366256] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 21.372804] tegra-i2c 7000c700.i2c: — register dump for debugging ----
[ 21.379786] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 21.385495] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 21.392206] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 21.397885] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 21.403871] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 21.409119] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 21.409152] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
Ubuntu 18.04.5 LTS nvidia ttyS0
