Only some Jetson Nanos work on my custom carrier board
I’ve designed a custom carrier board for Jetson Nano, but some Jetson Nanos won’t work on it. Some work fine, but some won’t even boot.
I was wondering what I could have done wrong, and here are my questions:
  1. Pin 240 (SLEEP/WAKE): I left it open. Didn’t add a pullup to 5V on it. Should I’ve put a pullup on it even though I don’t use this pin? Also pin 239 (SYS_RESET) and pin 214 (FORCE_RECOVERY) are left open. I just connected them to a connector with no pullups or anything else.
  2. On pins 124 and 212 I didn’t add pullups. They’re simply GPIO02 and GPIO10, but on the NVIDIA development kit carrier board they have signals BT_M2_WAKE_AP and M2_E_ALERT with pullups. Should I’ve added those pullups? Note also that I left open all pins from GPIO00 to GPIO07 and GPIO09 to GPIO13.
  3. Searching the forums for a solution to this problem I found this post: Jetson Nano module not working on custom carrier board - Could this be the problem? Jetson Nanos that come with the development kit won’t work on custom carrier boards? Strange that all Jetson Nanos I’ve tested on my custom carrier board came from the NVIDIA development kit.
Thanks for your help,
Ed
Hi, please confirm your power up sequence is similar to below one in Design guide. And you can check your design based on the items one by one in the checklist sheet attached in the Design Guide doc.
I checked with the oscilloscope all those signals, and when I power on my custom carrier board first VCC gets to ~4.961V. Then, SHUTDOWN_REQ goes high also to ~4.961V at the same time VCC goes high. About 350ms later POWER_EN is set high by the custom carrier board, with all decoupling capacitors fully charged and VCC stable. But SYS_RESET is then expected to go high after some time, but it stays low. Never goes high, even a minute later.
Note that some Jetson Nanos will work fine on my custom carrier board, but some won’t. All of them will work on the NVIDIA carrier board that comes with the development kit. My custom carrier board holds 4 Jetson Nanos, and it’s the same result in all 4 slots: some will work fine, but some won’t even power up.
EDIT: I tried changing the time POWER_EN goes high after VCC=5V to 1ms, 2ms, 5ms and 10ms but still same result: SYS_RESET stays low and Jetson Nano won’t boot.
No clue got. You may need to check your design carefully since some works while others not. Did you check the checklist sheet one by one?
Well, I reviewed the checklist and this is what I assume:
For power on (to get SYS_RESET=1), all I need is to wait for a stable 5V within tolerances (so my 4.961V is fine), then set POWER_EN high, and finally wait for SYS_RESET high to turn on all other supplies (3.3V, 1.8V, etc).
I am indeed not connecting SYS_RESET to the EN pin of my 3.3V and 1.8V regulators. But since only 1.8V goes to the Jetson Nano pins, I removed the 1.8V regulator to see if SYS_RESET would go high. But still it doesn’t.
I also saw on other posts that there’s a new requirement for a minimum of 400ms between VDD_IN and POWER_EN=1, so I changed a resistor on my custom carrier board to set this delay to ~1s. Still, no SYS_RESET.
My custom carrier board only uses:
  • SPI0 pins
  • FAN_TACH (pin 208) and FAN_PWM (pin 230) pins
  • Ethernet pins (GBE)
All other pins are left open except for the power pins (VDD_IN and GND pins), POWER_EN (pin 237) and SHUTDOWN_REQ (pin 233). So, is there anything else I could have missed that is preventing SYS_RESET to go high after POWER_EN=1? Note that with the 1.8V regulator removed, the SPI0/FAN pins are not driven.
Follow images of how I am controlling POWER_EN based on SHUTDOWN_REQ, fan, SPI and Ethernet pins:
I found the problem that was causing SYS_RESET to stay low. It was simply a PCB design mistake making the signal not go to the proper pin on the connector. Sorry about that.
Either way, the main issue remains where only some Jetson Nanos will work on my custom carrier board. But I managed to build a serial interface to convert UART2_TXD to RS232, and here are the debug output of the Jetson Nano that won’t work on my custom carrier board but will work on NVIDIA’s kit:
[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-b1625959)
[0000.131] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.139] Power-up reason: pmc por
[0000.142] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.148] pmic max77620 NVERC : 0x40
[0000.151] RamCode = 0
[0000.154] Platform has DDR4 type RAM
[0000.157] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x242df3
[0000.173] Entering ramdump check
[0000.176] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0,  RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.189] Sdram initialization is successful
[0000.193] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.205] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.211] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.217] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.260] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.270] BoardID = 3448, SKU = 0x0
[0000.273] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.277] Nano-SD: checking PT table on QSPI ...
[0000.281] Initialize FailControl
[0000.284] Read PT from (2:0)
[0000.315] PT crc32 and magic check passed.
[0000.318] Using BFS PT to query partitions
[0000.324] Loading Tboot-CPU binary
[0000.352] Verifying TBC in OdmNonSecureSBK mode
[0000.364] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.371] Bootloader downloaded successfully.
[0000.375] Downloaded Tboot-CPU binary to 0xa0000258
[0000.380] MAX77620_GPIO5 configured
[0000.383] CPU power rail is up
[0000.386] CPU clock enabled
[0000.390] Performing RAM repair
[0000.393] Updating A64 Warmreset Address to 0xa00002e9
[0000.398] BoardID = 3448, SKU = 0x0
[0000.401] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.405] Nano-SD: checking PT table on QSPI ...
[0000.409] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.415] Loading NvTbootBootloaderDTB
[0000.481] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.553] Bootloader DTB Load Address: 0x83000000
[0000.558] BoardID = 3448, SKU = 0x0
[0000.561] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.565] Nano-SD: checking PT table on QSPI ...
[0000.569] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.575] Loading NvTbootKernelDTB
[0000.641] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.713] Kernel DTB Load Address: 0x83100000
[0000.717] BoardID = 3448, SKU = 0x0
[0000.720] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.724] Nano-SD: checking PT table on QSPI ...
[0000.728] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.736] Loading cboot binary
[0000.852] Verifying EBT in OdmNonSecureSBK mode
[0000.894] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.901] Bootloader downloaded successfully.
[0000.905] BoardID = 3448, SKU = 0x0
[0000.908] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.912] Nano-SD: checking PT table on QSPI ...
[0000.916] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.922] PT: Partition NCT NOT found !
[0000.926] Warning: Find Partition via PT Failed
[0000.930] Next binary entry address: 0x92c00258
[0000.935] BoardId: 3448
[0000.939] Overriding pmu board id with proc board id
[0000.944] Display board id is not available
[0000.948] BoardID = 3448, SKU = 0x0
[0000.952] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.956] Nano-SD: checking PT table on QSPI ...
[0000.960] NvTbootFailControlDoFailover: No failover; Continuing ...
[0001.067] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.156] /bpmp deleted
[0001.159] SC7EntryFw header found loaded at 0xff700000
[0001.567] OVR2 PMIC
[0001.569] Bpmp FW successfully loaded
[0001.572] BoardID = 3448, SKU = 0x0
[0001.575] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.579] Nano-SD: checking PT table on QSPI ...
[0001.584] NvTbootFailControlDoFailover: No failover; Continuing ...
[0001.590] WB0 init successfully at 0xff780000
[0001.595] Verifying NvTbootWb0 in OdmNonSecureSBK mode
[0001.600] Set NvDecSticky Bits
[0001.603] GSC2 address ff53fffc value c0edbbcc
[0001.610] GSC MC Settings done
[0001.613] BoardID = 3448, SKU = 0x0
[0001.616] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.620] Nano-SD: checking PT table on QSPI ...
[0001.624] NvTbootFailControlDoFailover: No failover; Continuing ...
[0001.631] TOS Image length 53680
[0001.634]  Monitor size 53680
[0001.637]  OS size 0
[0001.652] Secure Os AES-CMAC Verification Success!
[0001.657] TOS image cipher info: plaintext
[0001.661] Loading and Validation of Secure OS Successful
[0001.676] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.681] NvTbootPackSdramParams: start.
[0001.686] NvTbootPackSdramParams: done.
[0001.690] Tegraboot started after 52341 us
[0001.694] Basic modules init took 937431 us
[0001.698] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
[0001.703] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.709] Next stage binary read took 102860 us
[0001.713] Carveout took -132463 us
[0001.716] CPU initialization took 770744 us
[0001.720] Total time taken by TegraBoot 1678572 us
[0001.725] Starting CPU & Halting co-processor
64NOTICE:  BL31: v1.3(release):f9bf1e1
NOTICE:  BL31: Built : 21:16:40, Jun  8 2023
ERROR:   Error initializing runtime service trusty_fast
[0001.848] RamCode = 0
[0001.857] LPDDR4 Training: found 4 entries (2 nominal, 2 derated)
[0001.863] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.876] EMC Training Successful
[0001.879] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.892] EMC Training Successful
[0001.895] 408000 not found in DVFS table
[0001.935] RamCode = 0
[0001.941] DT Write: emc-table@204000 succeeded
[0001.948] DT Write: emc-table@1600000 succeeded
[0001.956] DT Write: emc-table-derated@204000 succeeded
[0001.965] DT Write: emc-table-derated@1600000 succeeded
[0001.970] LPDDR4 Training: Write DT: Number of tables = 4
[0002.026]
[0002.027] Debug Init done
[0002.030] Marked DTB cacheable
[0002.032] Bootloader DTB loaded at 0x83000000
[0002.037] Marked DTB cacheable
[0002.040] Kernel DTB loaded at 0x83100000
[0002.044] DeviceTree Init done
[0002.059] Pinmux applied successfully
[0002.064] gicd_base: 0x50041000
[0002.067] gicc_base: 0x50042000
[0002.070] Interrupts Init done
[0002.075] Using base:0x60005090 & irq:208 for tick-timer
[0002.080] Using base:0x60005098 for delay-timer
[0002.085] platform_init_timer: DONE
[0002.088] Timer(tick) Init done
[0002.092] osc freq = 38400 khz
[0002.096]
[0002.097] Welcome to L4T Cboot
[0002.100]
[0002.101] Cboot Version: 00.00.2018.01-t210-acb23272
[0002.106] calling constructors
[0002.109] initializing heap
[0002.112] initializing threads
[0002.115] initializing timers
[0002.118] creating bootstrap completion thread
[0002.122] top of bootstrap2()
[0002.125] CPU: ARM Cortex A57
[0002.128] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0002.133] initializing platform
[0002.141] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0002.145] ID LSB = 0x36, ID-CFI len = 194 bytes
[0002.150] Macronix QSPI chip present
[0002.153] SPI device register
[0002.156] init boot device
[0002.159] allocating memory for boot device(SPI)
[0002.164] registering boot device
[0002.172] QSPI bdev is already initialized
[0002.176] Enable APE clock
[0002.178] Un-powergate APE partition
[0002.182] of_register: registering tegra_udc to of_hal
[0002.187] of_register: registering inv20628-driver to of_hal
[0002.193] of_register: registering ads1015-driver to of_hal
[0002.198] of_register: registering lp8557-bl-driver to of_hal
[0002.204] of_register: registering bq2419x_charger to of_hal
[0002.210] of_register: registering bq27441_fuel_gauge to of_hal
[0002.222] gpio framework initialized
[0002.226] of_register: registering tca9539_gpio to of_hal
[0002.231] of_register: registering tca9539_gpio to of_hal
[0002.237] of_register: registering i2c_bus_driver to of_hal
[0002.242] of_register: registering i2c_bus_driver to of_hal
[0002.248] of_register: registering i2c_bus_driver to of_hal
[0002.253] pmic framework initialized
[0002.257] of_register: registering max77620_pmic to of_hal
[0002.262] regulator framework initialized
[0002.266] of_register: registering tps65132_bl_driver to of_hal
[0002.272] initializing target
[0002.279] gpio_driver_register: register 'tegra_gpio_driver' driver
[0002.287] board ID = D78, board SKU = 0
[0002.291] Skipping Z3!
[0002.296] fixed regulator driver initialized
[0002.317] initializing OF layer
[0002.320] NCK carveout not present
[0002.324] Skipping dts_overrides
[0002.328] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.347] I2C Bus Init done
[0002.350] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.361] I2C Bus Init done
[0002.363] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.374] I2C Bus Init done
[0002.377] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.388] I2C Bus Init done
[0002.391] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.402] I2C Bus Init done
[0002.404] of_children_init: Ops found for compatible string maxim,max77620
[0002.415] max77620_init using irq 118
[0002.420] register 'maxim,max77620' pmic
[0002.425] gpio_driver_register: register 'max77620-gpio' driver
[0002.431] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.442] I2C Bus Init done
[0002.446] NCK carveout not present
[0002.457] Find /i2c@7000c000's alias i2c0
[0002.461] get eeprom at 1-a0, size 256, type 0
[0002.471] Find /i2c@7000c500's alias i2c2
[0002.475] get eeprom at 3-a0, size 256, type 0
[0002.479] get eeprom at 3-ae, size 256, type 0
[0002.484] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.489] I2C slave not started
[0002.492] I2C write failed
[0002.495] Writing offset failed
[0002.498] eeprom_init: EEPROM read failed
[0002.502] pm_ids_update: eeprom init failed
[0002.506] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.536] pm_ids_update: The pm board id is 3448-0000-400
[0002.543] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.551] pm_ids_update: pm id update successful
[0002.556] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.561] I2C slave not started
[0002.564] I2C write failed
[0002.567] Writing offset failed
[0002.570] eeprom_init: EEPROM read failed
[0002.574] pm_ids_update: eeprom init failed
[0002.604] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.610] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.618] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.624] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.632] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:3c:d7:ab
[0002.639] Plugin Manager: Parse ODM data 0x000a4000
[0002.652] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.668] Find /i2c@7000c000's alias i2c0
[0002.672] get eeprom at 1-a0, size 256, type 0
[0002.682] Find /i2c@7000c500's alias i2c2
[0002.686] get eeprom at 3-a0, size 256, type 0
[0002.690] get eeprom at 3-ae, size 256, type 0
[0002.694] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.700] I2C slave not started
[0002.703] I2C write failed
[0002.705] Writing offset failed
[0002.708] eeprom_init: EEPROM read failed
[0002.712] pm_ids_update: eeprom init failed
[0002.716] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.747] pm_ids_update: The pm board id is 3448-0000-400
[0002.753] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.760] pm_ids_update: pm id update successful
[0002.765] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.770] I2C slave not started
[0002.773] I2C write failed
[0002.776] Writing offset failed
[0002.779] eeprom_init: EEPROM read failed
[0002.782] pm_ids_update: eeprom init failed
[0002.813] Add serial number:1420521017243 as DT property
[0002.821] Applying platform configs
[0002.828] platform-init is not present. Skipping
[0002.833] calling apps_init()
[0002.838] Couldn't find GPT header
[0002.843] Proceeding to Cold Boot
[0002.846] starting app android_boot_app
[0002.850] Device state: unlocked
[0002.853] display console init
[0002.863] could not find regulator
[0002.866] hdmi cable connected
[0002.902] DT entry for leds-pwm not found
[0004.877] I2C transfer timeout
[0004.880] I2C write failed
[0004.883] Writing offset failed
[0004.886] could not read edid
[0004.891] tmds-config node not found
[0004.895] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting 'avdd-io-hdmi-dp' regulator to 1050000 micro volts
[0004.910] setting 'vdd-1v8' regulator to 1800000 micro volts
[0004.917] could not find regulator
[0004.921] could not find regulator
[0004.924] could not find regulator
[0004.952] using default cmu settings
[0004.956] dc_hdmi_enable, starting HDMI initialisation
[0004.962] dc_hdmi_enable, HDMI initialisation complete
[0004.967] list and configure display window
[0004.972] display console init completed
[0004.980] subnode volume_up is not found !
[0004.984] subnode back is not found !
[0004.987] subnode volume_down is not found !
[0004.992] subnode menu is not found !
[0004.995] Gpio keyboard init success
[0005.076] found decompressor handler: lz4-legacy
[0005.090] decompressing blob (type 1)...
[0005.157] load_bmp_blob: panelresolution=480 type=0
[0005.162] -------> se_aes_verify_sbk_clear: 747
[0005.166] se_aes_verify_sbk_clear: Error
[0005.170] SE operation failed
[0005.173] bl_battery_charging: connected to external power supply
[0005.186] device_query_partition_size: failed to open partition spiflash0:MSC !
[0005.193] MSC Partition not found
[0005.199] device_query_partition_size: failed to open partition spiflash0:USP !
[0005.207] USP partition read failed!
[0005.210] blob_init: blob-partition USP header read failed
[0005.216] android_boot Unable to update recovery partition
[0005.221] kfs_getpartname: name = LNX
[0005.225] Loading kernel from LNX
[0005.234] Found 19 BFS partitions in "spiflash0"
[0005.558] load kernel from storage
[0005.563] decompressor handler not found
[0005.833] Successfully loaded kernel and ramdisk images
[0005.838] board ID = D78, board SKU = 0
[0005.843] sdmmc node status = okay
[0005.846] sdcard instance = 0
[0005.849] sdmmc cd-inverted
[0005.852] sdcard gpio handle 0x5b
[0005.855] sdcard gpio pin 0xc9
[0005.858] sdcard gpio flags 0x0
[0005.861] vmmc-supply 0x9d
[0005.864] cd_gpio_pin = 201
[0005.867] pin_state = 0
[0005.869] Found sdcard
[0005.871] SD-card IS present ...
[0005.874] load_and_boot_kernel: SD card detected OK
[0005.880] load_bmp_blob: panelresolution=480 type=0
[0005.954] display bmp image done
[0005.957] NCK carveout not present
[0005.960] Skipping dts_overrides
[0005.963] NCK carveout not present
[0005.974] Find /i2c@7000c000's alias i2c0
[0005.978] get eeprom at 1-a0, size 256, type 0
[0005.988] Find /i2c@7000c500's alias i2c2
[0005.992] get eeprom at 3-a0, size 256, type 0
[0005.996] get eeprom at 3-ae, size 256, type 0
[0006.001] pm_ids_update: Updating 1,a0, size 256, type 0
[0006.006] I2C slave not started
[0006.009] I2C write failed
[0006.012] Writing offset failed
[0006.015] eeprom_init: EEPROM read failed
[0006.019] pm_ids_update: eeprom init failed
[0006.023] pm_ids_update: Updating 3,a0, size 256, type 0
[0006.053] pm_ids_update: The pm board id is 3448-0000-400
[0006.060] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0006.069] pm_ids_update: pm id update successful
[0006.073] pm_ids_update: Updating 3,ae, size 256, type 0
[0006.079] I2C slave not started
[0006.081] I2C write failed
[0006.084] Writing offset failed
[0006.087] eeprom_init: EEPROM read failed
[0006.091] pm_ids_update: eeprom init failed
[0006.121] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0006.127] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0006.135] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0006.141] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0006.150] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:3c:d7:ab
[0006.156] Plugin Manager: Parse ODM data 0x000a4000
[0006.169] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0006.177] Add serial number:1420521017243 as DT property
[0006.187] "bpmp" doesn't exist, creating
[0006.193] Updated bpmp info to DTB
[0006.198] Updated initrd info to DTB
[0006.201] "proc-board" doesn't exist, creating
[0006.208] Updated board info to DTB
[0006.211] "pmu-board" doesn't exist, creating
[0006.217] Updated board info to DTB
[0006.220] "display-board" doesn't exist, creating
[0006.226] Updated board info to DTB
[0006.230] "reset" doesn't exist, creating
[0006.234] Updated reset info to DTB
[0006.238] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt tegra_fbmem=0x140000@0x92ca9000 is_hdmi_initialised=1
[0006.277] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0006.282] boot image cmdline: root=PARTUUID=3d922640-4ee2-4f36-b873-17b1a1e923a8 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0006.298] Updated bootarg info to DTB
[0006.302] Adding uuid 00000001646db807000000000e078340 to DT
[0006.308] Adding eks info 0 to DT
[0006.314] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0006.320] Updated memory info to DTB
[0006.329] set vdd_core voltage to 1125 mv
[0006.333] setting 'vdd-core' regulator to 1125000 micro volts
[0006.339] Found secure-pmc; disable BPMP
U-Boot 2020.04-g4335beb (Jun 08 2023 - 21:16:44 -0700)
SoC: tegra210
Model: NVIDIA Jetson Nano Developer Kit
Board: NVIDIA P3450-0000
DRAM:  4 GiB
MMC:   sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from SPI Flash... SF: Detected mx25u3235f with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Hit any key to stop autoboot:  2  0
Tegra210 (P3450-0000) # MC:   sôû÷*** Wiû {
I see this warning about bad CRC near the end. Is this something that could be the issue?
Thanks for your help.
PS: I also see this “Hit any key to stop autoboot” at the end. But UART2_RXD is left open on my custom carrier board. So, it could be receiving noise, which is “any key”.
Actually you don’t need to ask whether CRC error is related to this issue.
As you said you have devkit, you can just put that module to devkit and see if you also see such error.
From my point of view that crc error does not matter.
Here’s the UART2_TXD output of that same Jetson Nano on the NVIDIA’s kit:
[0000.216] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.259] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0001.066] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.583] NvTbootFailControlDoFailover: No failover; Continuing ...
[0001.660] Loading and Validation of Secure OS Successful
[0001.690] Tegraboot started after 52328 us
[0001.694] Basic modules init took 937406 us
[0001.713] Carveout took -132465 us
[0001.716] CPU initialization took 770746 us
[0001.720] Total time taken by TegraBoot 1678547 us
[0002.026]
[0002.096]
[0002.100]
[0002.163] registering boot device
[0002.236] of_register: registering i2c_bus_driver to of_hal
[0002.360] I2C Bus Init done
[0002.494] Writing offset failed
[0002.497] eeprom_init: EEPROM read failed
[0002.501] pm_ids_update: eeprom init failed
[0002.586] pm_ids_update: The pm board id is 3449-0000-400
[0002.592] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.601] pm_ids_update: pm id update successful
[0002.631] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.637] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.645] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.651] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.660] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:3c:d7:ab
[0002.666] Plugin Manager: Parse ODM data 0x000a4000
[0002.679] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.695] Find /i2c@7000c000's alias i2c0
[0002.699] get eeprom at 1-a0, size 256, type 0
[0002.709] Find /i2c@7000c500's alias i2c2
[0002.713] get eeprom at 3-a0, size 256, type 0
[0002.717] get eeprom at 3-ae, size 256, type 0
[0002.722] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.727] I2C slave not started
[0002.730] I2C write failed
[0002.732] Writing offset failed
[0002.736] eeprom_init: EEPROM read failed
[0002.739] pm_ids_update: eeprom init failed
[0002.744] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.774] pm_ids_update: The pm board id is 3448-0000-400
[0002.780] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.787] pm_ids_update: pm id update successful
[0002.792] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.822] pm_ids_update: The pm board id is 3449-0000-400
[0002.828] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.835] pm_ids_update: pm id update successful
[0002.866] Add serial number:1420521017243 as DT property
[0002.874] Applying platform configs
[0002.881] platform-init is not present. Skipping
[0002.886] calling apps_init()
[0002.892] Couldn't find GPT header
[0002.896] Proceeding to Cold Boot
[0002.899] starting app android_boot_app
[0002.903] Device state: unlocked
[0002.906] display console init
[0002.916] could not find regulator
[0002.939] hdmi cable not connected
[0002.943] is_hdmi_needed: HDMI not connected, returninDT entry for leds-pwm not found
g[0002.955]  false
[0002.956] hdmi is not connected
[0002.959] sor0 is not supported
[0002.962] display_console_init: no valid display out_type
[0002.971] subnode volume_up is not found !
[0002.975] subnode back is not found !
[0002.979] subnode volume_down is not found !
[0002.983] subnode menu is not found !
[0002.986] Gpio keyboard init success
[0003.067] found decompressor handler: lz4-legacy
[0003.081] decompressing blob (type 1)...
[0003.147] display_resolution: No display init
[0003.151] Failed to retrieve display resolution
[0003.156] Could not load/initialize BMP blob...ignoring
[0003.161] -------> se_aes_verify_sbk_clear: 747
[0003.165] se_aes_verify_sbk_clear: Error
[0003.169] SE operation failed
[0003.172] bl_battery_charging: connected to external power supply
[0003.182] display_console_ioctl: No display init
[0003.187] switch_backlight failed
[0003.193] device_query_partition_size: failed to open partition spiflash0:MSC !
[0003.200] MSC Partition not found
[0003.206] device_query_partition_size: failed to open partition spiflash0:USP !
[0003.214] USP partition read failed!
[0003.217] blob_init: blob-partition USP header read failed
[0003.223] android_boot Unable to update recovery partition
[0003.228] kfs_getpartname: name = LNX
[0003.232] Loading kernel from LNX
[0003.241] Found 19 BFS partitions in "spiflash0"
[0003.562] load kernel from storage
[0003.567] decompressor handler not found
[0003.834] Successfully loaded kernel and ramdisk images
[0003.839] board ID = D78, board SKU = 0
[0003.844] sdmmc node status = okay
[0003.847] sdcard instance = 0
[0003.850] sdmmc cd-inverted
[0003.852] sdcard gpio handle 0x5b
[0003.856] sdcard gpio pin 0xc9
[0003.859] sdcard gpio flags 0x0
[0003.862] vmmc-supply 0x9d
[0003.864] cd_gpio_pin = 201
[0003.867] pin_state = 0
[0003.869] Found sdcard
[0003.871] SD-card IS present ...
[0003.875] load_and_boot_kernel: SD card detected OK
[0003.881] display_resolution: No display init
[0003.885] Failed to retrieve display resolution
[0003.889] bmp blob is not loaded and initialized
[0003.894] Failed to display boot-logo
[0003.898] NCK carveout not present
[0003.901] Skipping dts_overrides
[0003.904] NCK carveout not present
[0003.915] Find /i2c@7000c000's alias i2c0
[0003.919] get eeprom at 1-a0, size 256, type 0
[0003.929] Find /i2c@7000c500's alias i2c2
[0003.933] get eeprom at 3-a0, size 256, type 0
[0003.937] get eeprom at 3-ae, size 256, type 0
[0003.942] pm_ids_update: Updating 1,a0, size 256, type 0
[0003.947] I2C slave not started
[0003.950] I2C write failed
[0003.953] Writing offset failed
[0003.956] eeprom_init: EEPROM read failed
[0003.960] pm_ids_update: eeprom init failed
[0003.964] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.994] pm_ids_update: The pm board id is 3448-0000-400
[0004.001] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0004.010] pm_ids_update: pm id update successful
[0004.014] pm_ids_update: Updating 3,ae, size 256, type 0
[0004.044] pm_ids_update: The pm board id is 3449-0000-400
[0004.051] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0004.059] pm_ids_update: pm id update successful
[0004.089] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0004.095] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0004.104] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0004.109] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0004.118] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:3c:d7:ab
[0004.124] Plugin Manager: Parse ODM data 0x000a4000
[0004.137] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0004.146] Add serial number:1420521017243 as DT property
[0004.155] "bpmp" doesn't exist, creating
[0004.161] Updated bpmp info to DTB
[0004.166] Updated initrd info to DTB
[0004.170] "proc-board" doesn't exist, creating
[0004.176] Updated board info to DTB
[0004.179] "pmu-board" doesn't exist, creating
[0004.185] Updated board info to DTB
[0004.189] "display-board" doesn't exist, creating
[0004.194] Updated board info to DTB
[0004.198] "reset" doesn't exist, creating
[0004.203] Updated reset info to DTB
[0004.206] display_console_ioctl: No display init
[0004.210] display_console_ioctl: No display init
[0004.215] display_console_ioctl: No display init
[0004.220] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt
[0004.254] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0004.260] boot image cmdline: root=PARTUUID=3d922640-4ee2-4f36-b873-17b1a1e923a8 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0004.275] Updated bootarg info to DTB
[0004.279] Adding uuid 00000001646db807000000000e078340 to DT
[0004.285] Adding eks info 0 to DT
[0004.291] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0004.297] Updated memory info to DTB
[0004.306] set vdd_core voltage to 1125 mv
[0004.310] setting 'vdd-core' regulator to 1125000 micro volts
[0004.316] Found secure-pmc; disable BPMP
SoC: tegra210
DRAM:  4 GiB
In:    serial
Out:   serial
Err:   serial
Hit any key to stop autoboot:  2  1  0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
845 bytes read in 20 ms (41 KiB/s)
1:	primary kernel
Retrieving file: /boot/initrd
7159654 bytes read in 334 ms (20.4 MiB/s)
Retrieving file: /boot/Image
34707464 bytes read in 1517 ms (21.8 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt  earlycon=uart8250,mmio32,0x70006000  root=PARTUUID=3d922640-4ee2-4f36-b873-17b1a1e923a8 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
## Flattened Device Tree blob at 83100000
   Booting using the fdt blob at 0x83100000
ERROR: reserving fdt memory region failed (addr=83410000 size=10000)
ERROR: reserving fdt memory region failed (addr=83400000 size=10000)
ERROR: reserving fdt memory region failed (addr=0 size=0)
   Using Device Tree in place at 0000000083100000, end 000000008317dfff
copying carveout for /host1x@50000000/dc@54200000...
copying carveout for /host1x@50000000/dc@54240000...
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.337-tegra (buildbrain@mobile-u64-5434-d8000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Thu Jun 8 21:19:14 PDT 2023
[    0.000000] Boot CPU: AArch64 Processor [411fd071]
[    0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[    0.000000] OF: fdt: - 80000000 ,  7ee00000
[    0.000000] OF: fdt: - 100000000 ,  7f200000
[    0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[    0.000000] bootconsole [uart8250] enabled
[    1.113142] tegradc tegradc.1: dpd enable lookup fail:-19
[    1.618886] Host read timeout at address 545c00c4
[    1.828309] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.835941] imx219 7-0010: board setup failed
[    1.864383] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.871999] imx219 8-0010: board setup failed
[    7.888101] cgroup: cgroup2: unknown option "nsdelegate"
[    9.166355] random: systemd-journal: uninitialized urandom read (16 bytes read)
[    9.167004] random: systemd: uninitialized urandom read (16 bytes read)
[    9.167101] random: systemd: uninitialized urandom read (16 bytes read)
[    9.917958] random: crng init done
[    9.921369] random: 247 urandom warning(s) missed due to ratelimiting
[    9.953434] using random self ethernet address
[    9.958030] using random host ethernet address
[   10.853547] using random self ethernet address
[   10.858893] using random host ethernet address
Ubuntu 18.04.6 LTS atman-mpv ttyS0
atman-mpv login: [   13.623250] tegra-i2c 7000c000.i2c: no acknowledge from address 0x50
[   13.631307] tegra-i2c 7000c400.i2c: no acknowledge from address 0x50
Still has the warning about bad CRC, but it goes on.
This is another Jetson Nano on my custom carrier board, but this time it’s the Jetson Nano that will work on my custom board:
[0000.165] Serial Number of Pmic Max77663: 0x2503f3
[0001.690] Tegraboot started after 52326 us
[0001.694] Basic modules init took 937420 us
[0001.713] Carveout took -132462 us
[0001.716] CPU initialization took 770742 us
[0001.720] Total time taken by TegraBoot 1678560 us
[0002.026]
[0002.096]
[0002.100]
[0002.182] QSPI bdev is already initialized
[0002.186] Enable APE clock
[0002.188] Un-powergate APE partition
[0002.192] of_register: registering tegra_udc to of_hal
[0002.197] of_register: registering inv20628-driver to of_hal
[0002.203] of_register: registering ads1015-driver to of_hal
[0002.208] of_register: registering lp8557-bl-driver to of_hal
[0002.214] of_register: registering bq2419x_charger to of_hal
[0002.220] of_register: registering bq27441_fuel_gauge to of_hal
[0002.232] gpio framework initialized
[0002.236] of_register: registering tca9539_gpio to of_hal
[0002.241] of_register: registering tca9539_gpio to of_hal
[0002.246] of_register: registering i2c_bus_driver to of_hal
[0002.252] of_register: registering i2c_bus_driver to of_hal
[0002.258] of_register: registering i2c_bus_driver to of_hal
[0002.263] pmic framework initialized
[0002.267] of_register: registering max77620_pmic to of_hal
[0002.272] regulator framework initialized
[0002.276] of_register: registering tps65132_bl_driver to of_hal
[0002.282] initializing target
[0002.289] gpio_driver_register: register 'tegra_gpio_driver' driver
[0002.297] board ID = D78, board SKU = 0
[0002.301] Skipping Z3!
[0002.306] fixed regulator driver initialized
[0002.327] initializing OF layer
[0002.330] NCK carveout not present
[0002.334] Skipping dts_overrides
[0002.338] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.357] I2C Bus Init done
[0002.360] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.370] I2C Bus Init done
[0002.373] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.384] I2C Bus Init done
[0002.387] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.398] I2C Bus Init done
[0002.400] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.412] I2C Bus Init done
[0002.414] of_children_init: Ops found for compatible string maxim,max77620
[0002.425] max77620_init using irq 118
[0002.430] register 'maxim,max77620' pmic
[0002.434] gpio_driver_register: register 'max77620-gpio' driver
[0002.441] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.452] I2C Bus Init done
[0002.456] NCK carveout not present
[0002.467] Find /i2c@7000c000's alias i2c0
[0002.471] get eeprom at 1-a0, size 256, type 0
[0002.481] Find /i2c@7000c500's alias i2c2
[0002.485] get eeprom at 3-a0, size 256, type 0
[0002.489] get eeprom at 3-ae, size 256, type 0
[0002.493] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.499] I2C slave not started
[0002.502] I2C write failed
[0002.504] Writing offset failed
[0002.507] eeprom_init: EEPROM read failed
[0002.511] pm_ids_update: eeprom init failed
[0002.515] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.546] pm_ids_update: The pm board id is 3448-0000-400
[0002.553] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.561] pm_ids_update: pm id update successful
[0002.566] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.571] I2C slave not started
[0002.574] I2C write failed
[0002.577] Writing offset failed
[0002.580] eeprom_init: EEPROM read failed
[0002.584] pm_ids_update: eeprom init failed
[0002.614] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.620] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.628] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.634] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.642] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:3c:d4:41
[0002.649] Plugin Manager: Parse ODM data 0x000a4000
[0002.662] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.678] Find /i2c@7000c000's alias i2c0
[0002.682] get eeprom at 1-a0, size 256, type 0
[0002.692] Find /i2c@7000c500's alias i2c2
[0002.695] get eeprom at 3-a0, size 256, type 0
[0002.700] get eeprom at 3-ae, size 256, type 0
[0002.704] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.710] I2C slave not started
[0002.713] I2C write failed
[0002.715] Writing offset failed
[0002.718] eeprom_init: EEPROM read failed
[0002.722] pm_ids_update: eeprom init failed
[0002.726] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.756] pm_ids_update: The pm board id is 3448-0000-400
[0002.763] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.770] pm_ids_update: pm id update successful
[0002.774] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.780] I2C slave not started
[0002.783] I2C write failed
[0002.785] Writing offset failed
[0002.788] eeprom_init: EEPROM read failed
[0002.792] pm_ids_update: eeprom init failed
[0002.823] Add serial number:1420521016891 as DT property
[0002.831] Applying platform configs
[0002.838] platform-init is not present. Skipping
[0002.843] calling apps_init()
[0002.848] Couldn't find GPT header
[0002.853] Proceeding to Cold Boot
[0002.856] starting app android_boot_app
[0002.860] Device state: unlocked
[0002.863] display console init
[0002.873] could not find regulator
[0002.876] hdmi cable connected
[0002.912] DT entry for leds-pwm not found
[0004.887] I2C transfer timeout
[0004.890] I2C write failed
[0004.893] Writing offset failed
[0004.896] could not read edid
[0004.901] tmds-config node not found
[0004.905] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting 'avdd-io-hdmi-dp' regulator to 1050000 micro volts
[0004.920] setting 'vdd-1v8' regulator to 1800000 micro volts
[0004.927] could not find regulator
[0004.931] could not find regulator
[0004.934] could not find regulator
[0004.962] using default cmu settings
[0004.966] dc_hdmi_enable, starting HDMI initialisation
[0004.972] dc_hdmi_enable, HDMI initialisation complete
[0004.977] list and configure display window
[0004.982] display console init completed
[0004.990] subnode volume_up is not found !
[0004.994] subnode back is not found !
[0004.997] subnode volume_down is not found !
[0005.002] subnode menu is not found !
[0005.005] Gpio keyboard init success
[0005.086] found decompressor handler: lz4-legacy
[0005.100] decompressing blob (type 1)...
[0005.167] load_bmp_blob: panelresolution=480 type=0
[0005.171] -------> se_aes_verify_sbk_clear: 747
[0005.176] se_aes_verify_sbk_clear: Error
[0005.180] SE operation failed
[0005.183] bl_battery_charging: connected to external power supply
[0005.196] device_query_partition_size: failed to open partition spiflash0:MSC !
[0005.203] MSC Partition not found
[0005.209] device_query_partition_size: failed to open partition spiflash0:USP !
[0005.216] USP partition read failed!
[0005.220] blob_init: blob-partition USP header read failed
[0005.225] android_boot Unable to update recovery partition
[0005.231] kfs_getpartname: name = LNX
[0005.234] Loading kernel from LNX
[0005.244] Found 19 BFS partitions in "spiflash0"
[0005.568] load kernel from storage
[0005.573] decompressor handler not found
[0005.843] Successfully loaded kernel and ramdisk images
[0005.848] board ID = D78, board SKU = 0
[0005.853] sdmmc node status = okay
[0005.856] sdcard instance = 0
[0005.859] sdmmc cd-inverted
[0005.862] sdcard gpio handle 0x5b
[0005.865] sdcard gpio pin 0xc9
[0005.868] sdcard gpio flags 0x0
[0005.871] vmmc-supply 0x9d
[0005.874] cd_gpio_pin = 201
[0005.876] pin_state = 0
[0005.879] Found sdcard
[0005.881] SD-card IS present ...
[0005.884] load_and_boot_kernel: SD card detected OK
[0005.890] load_bmp_blob: panelresolution=480 type=0
[0005.964] display bmp image done
[0005.967] NCK carveout not present
[0005.970] Skipping dts_overrides
[0005.973] NCK carveout not present
[0005.984] Find /i2c@7000c000's alias i2c0
[0005.988] get eeprom at 1-a0, size 256, type 0
[0005.998] Find /i2c@7000c500's alias i2c2
[0006.002] get eeprom at 3-a0, size 256, type 0
[0006.006] get eeprom at 3-ae, size 256, type 0
[0006.011] pm_ids_update: Updating 1,a0, size 256, type 0
[0006.016] I2C slave not started
[0006.019] I2C write failed
[0006.022] Writing offset failed
[0006.025] eeprom_init: EEPROM read failed
[0006.029] pm_ids_update: eeprom init failed
[0006.033] pm_ids_update: Updating 3,a0, size 256, type 0
[0006.063] pm_ids_update: The pm board id is 3448-0000-400
[0006.070] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0006.079] pm_ids_update: pm id update successful
[0006.083] pm_ids_update: Updating 3,ae, size 256, type 0
[0006.088] I2C slave not started
[0006.091] I2C write failed
[0006.094] Writing offset failed
[0006.097] eeprom_init: EEPROM read failed
[0006.101] pm_ids_update: eeprom init failed
[0006.131] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0006.137] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0006.145] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0006.151] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0006.160] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:3c:d4:41
[0006.166] Plugin Manager: Parse ODM data 0x000a4000
[0006.179] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0006.187] Add serial number:1420521016891 as DT property
[0006.197] "bpmp" doesn't exist, creating
[0006.203] Updated bpmp info to DTB
[0006.208] Updated initrd info to DTB
[0006.211] "proc-board" doesn't exist, creating
[0006.218] Updated board info to DTB
[0006.221] "pmu-board" doesn't exist, creating
[0006.227] Updated board info to DTB
[0006.230] "display-board" doesn't exist, creating
[0006.236] Updated board info to DTB
[0006.240] "reset" doesn't exist, creating
[0006.244] Updated reset info to DTB
[0006.248] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x140000@0x92ca9000 is_hdmi_initialised=1
[0006.287] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0006.292] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0006.305] Updated bootarg info to DTB
[0006.309] Adding uuid 00000001647056491800000004fe8380 to DT
[0006.315] Adding eks info 0 to DT
[0006.321] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0006.327] Updated memory info to DTB
[0006.336] set vdd_core voltage to 1075 mv
[0006.340] setting 'vdd-core' regulator to 1075000 micro volts
[0006.346] Found secure-pmc; disable BPMP
SoC: tegra210
DRAM:  4 GiB
In:    serial
Out:   serial
Err:   serial
Scanning mmc 1:1...
1:	primary kernel
34707464 bytes read in 1516 ms (21.8 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x140000@0x92ca9000 is_hdmi_initialised=1  earlycon=uart8250,mmio32,0x70006000  root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
Starting kernel ...
[    0.000000] Found tegra_fbmem: 00140000@92ca9000
[    1.354964] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.362607] imx219 7-0010: board setup failed
[    1.391038] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.398605] imx219 8-0010: board setup failed
I am not sure. But previous error one which “stops” the boot process looks more like you hit a key to stop the auto boot.
Yes, that was exactly it. The UART2_RXD was left open, floating. So, on some Jetson Nanos it would not receive noise, and progress normally through the boot. But on others UART2_RXD would receive noise, and that noise would act as a key being hit at that part, stopping the autoboot. So I tied UART2_RXD to GND and the problem stopped.
Question: Is it possible to disable this “Hit any key to stop autoboot” via software, or by any setting on the Jetson Nano?
Pulling to ground is not good. The default level on an UART is a logic high. Pulling high to 1.8V would be a better option.
