Hello. I try to load Jetson Nano but i had fail. I downloaded sd-card image, writed it to my sd-card, inserted card to Nano, installed system (entered username and password etc.). But Nano after that always rebooting.
Log
[0000.130] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.138] Power-up reason: pmc por
[0000.141] No Battery Present
[0000.144] pmic max77620 reset reason
[0000.147] pmic max77620 NVERC : 0x2
[0000.151] RamCode = 0
[0000.153] Platform has DDR4 type RAM
[0000.156] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x1532e4
[0000.172] Entering ramdump check
[0000.175] Get RamDumpCarveOut = 0x0
[0000.178] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.188] Sdram initialization is successful
[0000.192] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.198] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.204] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.210] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.216] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.233] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.259] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.269] BoardID = 3448, SKU = 0x0
[0000.272] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.276] Nano-SD: checking PT table on QSPI …
[0000.280] Initialize FailControl
[0000.283] Read PT from (2:0)
[0000.314] PT crc32 and magic check passed.
[0000.318] Using BFS PT to query partitions
[0000.324] Loading Tboot-CPU binary
[0000.352] Verifying TBC in OdmNonSecureSBK mode
[0000.362] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.369] Bootloader downloaded successfully.
[0000.373] Downloaded Tboot-CPU binary to 0xa0000258
[0000.378] MAX77620_GPIO5 configured
[0000.381] CPU power rail is up
[0000.384] CPU clock enabled
[0000.388] Performing RAM repair
[0000.391] Updating A64 Warmreset Address to 0xa00002e9
[0000.396] BoardID = 3448, SKU = 0x0
[0000.399] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.403] Nano-SD: checking PT table on QSPI …
[0000.407] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.413] Loading NvTbootBootloaderDTB
[0000.480] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.551] Bootloader DTB Load Address: 0x83000000
[0000.556] BoardID = 3448, SKU = 0x0
[0000.559] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.563] Nano-SD: checking PT table on QSPI …
[0000.567] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.573] Loading NvTbootKernelDTB
[0000.639] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.711] Kernel DTB Load Address: 0x83100000
[0000.715] BoardID = 3448, SKU = 0x0
[0000.718] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.722] Nano-SD: checking PT table on QSPI …
[0000.726] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.734] Loading cboot binary
[0000.850] Verifying EBT in OdmNonSecureSBK mode
[0000.892] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.899] Bootloader downloaded successfully.
[0000.903] BoardID = 3448, SKU = 0x0
[0000.906] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.910] Nano-SD: checking PT table on QSPI …
[0000.914] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.920] PT: Partition NCT NOT found !
[0000.924] Warning: Find Partition via PT Failed
[0000.928] Next binary entry address: 0x92c00258
[0000.933] BoardId: 3448
[0000.938] Overriding pmu board id with proc board id
[0000.942] Display board id is not available
[0000.947] BoardID = 3448, SKU = 0x0
[0000.950] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.954] Nano-SD: checking PT table on QSPI …
[0000.958] NvTbootFailControlDoFailover: No failover; Continuing …
[0001.065] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.121] /bpmp deleted
[0001.123] SC7EntryFw header found loaded at 0xff700000
[0001.311] OVR2 PMIC
[0001.313] Bpmp FW successfully loaded
[0001.316] BoardID = 3448, SKU = 0x0
[0001.320] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.323] Nano-SD: checking PT table on QSPI …
[0001.328] NvTbootFailControlDoFailover: No failover; Continuing …
[0001.335] WB0 init successfully at 0xff780000
[0001.339] Verifying NvTbootWb0 in OdmNonSecureSBK mode
[0001.344] Set NvDecSticky Bits
[0001.348] GSC2 address ff53fffc value c0edbbcc
[0001.354] GSC MC Settings done
[0001.357] BoardID = 3448, SKU = 0x0
[0001.360] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.364] Nano-SD: checking PT table on QSPI …
[0001.368] NvTbootFailControlDoFailover: No failover; Continuing …
[0001.375] TOS Image length 53680
[0001.378] Monitor size 53680
[0001.381] OS size 0
[0001.396] Secure Os AES-CMAC Verification Success!
[0001.401] TOS image cipher info: plaintext
[0001.405] Loading and Validation of Secure OS Successful
[0001.421] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.425] NvTbootPackSdramParams: start.
[0001.430] NvTbootPackSdramParams: done.
[0001.434] Tegraboot started after 51852 us
[0001.438] Basic modules init took 935929 us
[0001.442] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
[0001.448] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.453] Next stage binary read took 102859 us
[0001.457] Carveout took -132462 us
[0001.461] CPU initialization took 510783 us
[0001.465] Total time taken by TegraBoot 1417109 us
[0001.469] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):b5eeb33
NOTICE: BL31: Built : 08:56:32, Feb 19 2022
ERROR: Error initializing runtime service trusty_fast
[0001.591] RamCode = 0
[0001.596] LPDDR4 Training: Read DT: Number of tables = 2
[0001.601] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.614] EMC Training Successful
[0001.617] 408000 not found in DVFS table
[0001.623] RamCode = 0
[0001.627] DT Write: emc-table@204000 succeeded
[0001.632] DT Write: emc-table@1600000 succeeded
[0001.636] LPDDR4 Training: Write DT: Number of tables = 2
[0001.685]
[0001.686] Debug Init done
[0001.688] Marked DTB cacheable
[0001.691] Bootloader DTB loaded at 0x83000000
[0001.696] Marked DTB cacheable
[0001.699] Kernel DTB loaded at 0x83100000
[0001.703] DeviceTree Init done
[0001.716] Pinmux applied successfully
[0001.720] gicd_base: 0x50041000
[0001.724] gicc_base: 0x50042000
[0001.727] Interrupts Init done
[0001.731] Using base:0x60005090 & irq:208 for tick-timer
[0001.736] Using base:0x60005098 for delay-timer
[0001.740] platform_init_timer: DONE
[0001.744] Timer(tick) Init done
[0001.748] osc freq = 38400 khz
[0001.751]
[0001.753] Welcome to L4T Cboot
[0001.756]
[0001.757] Cboot Version: 00.00.2018.01-t210-a2f2e4b8
[0001.762] calling constructors
[0001.765] initializing heap
[0001.767] initializing threads
[0001.770] initializing timers
[0001.773] creating bootstrap completion thread
[0001.778] top of bootstrap2()
[0001.780] CPU: ARM Cortex A57
[0001.783] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.788] initializing platform
[0001.795] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.800] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.804] Macronix QSPI chip present
[0001.808] SPI device register
[0001.811] init boot device
[0001.813] allocating memory for boot device(SPI)
[0001.818] registering boot device
[0001.836] QSPI bdev is already initialized
[0001.840] Enable APE clock
[0001.843] Un-powergate APE partition
[0001.846] of_register: registering tegra_udc to of_hal
[0001.851] of_register: registering inv20628-driver to of_hal
[0001.857] of_register: registering ads1015-driver to of_hal
[0001.863] of_register: registering lp8557-bl-driver to of_hal
[0001.868] of_register: registering bq2419x_charger to of_hal
[0001.874] of_register: registering bq27441_fuel_gauge to of_hal
[0001.885] gpio framework initialized
[0001.889] of_register: registering tca9539_gpio to of_hal
[0001.894] of_register: registering tca9539_gpio to of_hal
[0001.900] of_register: registering i2c_bus_driver to of_hal
[0001.905] of_register: registering i2c_bus_driver to of_hal
[0001.911] of_register: registering i2c_bus_driver to of_hal
[0001.916] pmic framework initialized
[0001.920] of_register: registering max77620_pmic to of_hal
[0001.925] regulator framework initialized
[0001.929] of_register: registering tps65132_bl_driver to of_hal
[0001.935] initializing target
[0001.941] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.949] board ID = D78, board SKU = 0
[0001.953] Skipping Z3!
[0001.957] fixed regulator driver initialized
[0001.975] initializing OF layer
[0001.978] NCK carveout not present
[0001.981] Skipping dts_overrides
[0001.986] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.002] I2C Bus Init done
[0002.005] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.015] I2C Bus Init done
[0002.018] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.028] I2C Bus Init done
[0002.031] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.041] I2C Bus Init done
[0002.044] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.054] I2C Bus Init done
[0002.057] of_children_init: Ops found for compatible string maxim,max77620
[0002.067] max77620_init using irq 118
[0002.072] register ‘maxim,max77620’ pmic
[0002.076] gpio_driver_register: register ‘max77620-gpio’ driver
[0002.082] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.093] I2C Bus Init done
[0002.096] NCK carveout not present
[0002.106] Find /i2c@7000c000’s alias i2c0
[0002.110] get eeprom at 1-a0, size 256, type 0
[0002.119] Find /i2c@7000c500’s alias i2c2
[0002.122] get eeprom at 3-a0, size 256, type 0
[0002.127] get eeprom at 3-ae, size 256, type 0
[0002.131] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.137] I2C slave not started
[0002.140] I2C write failed
[0002.142] Writing offset failed
[0002.145] eeprom_init: EEPROM read failed
[0002.149] pm_ids_update: eeprom init failed
[0002.153] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.183] pm_ids_update: The pm board id is 3448-0000-400
[0002.190] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.199] pm_ids_update: pm id update successful
[0002.203] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.233] pm_ids_update: The pm board id is 3449-0000-400
[0002.239] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.247] pm_ids_update: pm id update successful
[0002.278] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.283] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.291] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.297] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.306] updating /chosen/nvidia,ethernet-mac node 00:04:4b:eb:fc:86
[0002.312] Plugin Manager: Parse ODM data 0x000a4000
[0002.324] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.339] Find /i2c@7000c000’s alias i2c0
[0002.343] get eeprom at 1-a0, size 256, type 0
[0002.351] Find /i2c@7000c500’s alias i2c2
[0002.355] get eeprom at 3-a0, size 256, type 0
[0002.360] get eeprom at 3-ae, size 256, type 0
[0002.364] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.369] I2C slave not started
[0002.372] I2C write failed
[0002.375] Writing offset failed
[0002.378] eeprom_init: EEPROM read failed
[0002.382] pm_ids_update: eeprom init failed
[0002.386] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.416] pm_ids_update: The pm board id is 3448-0000-400
[0002.422] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.429] pm_ids_update: pm id update successful
[0002.434] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.464] pm_ids_update: The pm board id is 3449-0000-400
[0002.470] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.477] pm_ids_update: pm id update successful
[0002.507] Add serial number:1423119032165 as DT property
[0002.515] Applying platform configs
[0002.522] platform-init is not present. Skipping
[0002.526] calling apps_init()
[0002.532] Couldn’t find GPT header
[0002.537] Proceeding to Cold Boot
[0002.540] starting app android_boot_app
[0002.544] Device state: unlocked
[0002.547] display console init
[0002.555] could not find regulator
[0002.578] hdmi cable not connected
[0002.582] is_hdmi_needed: HDMI not connected, returning false
[0002.587] hdmi is not connected
[0002.590] sor0 is not supportDT entry for leds-pwm not found
e[0002.599] d
[0002.601] display_console_init: no valid display out_type
[0002.608] subnode volume_up is not found !
[0002.612] subnode back is not found !
[0002.616] subnode volume_down is not found !
[0002.620] subnode menu is not found !
[0002.624] Gpio keyboard init success
[0002.704] found decompressor handler: lz4-legacy
[0002.719] decompressing blob (type 1)…
[0002.785] display_resolution: No display init
[0002.789] Failed to retrieve display resolution
[0002.794] Could not load/initialize BMP blob…ignoring
[0002.799] -------> se_aes_verify_sbk_clear: 747
[0002.803] se_aes_verify_sbk_clear: Error
[0002.807] SE operation failed
[0002.810] bl_battery_charging: connected to external power supply
[0002.819] display_console_ioctl: No display init
[0002.824] switch_backlight failed
[0002.830] device_query_partition_size: failed to open partition spiflash0:MSC !
[0002.837] MSC Partition not found
[0002.843] device_query_partition_size: failed to open partition spiflash0:USP !
[0002.851] USP partition read failed!
[0002.854] blob_init: blob-partition USP header read failed
[0002.860] android_boot Unable to update recovery partition
[0002.865] kfs_getpartname: name = LNX
[0002.869] Loading kernel from LNX
[0002.878] Found 19 BFS partitions in “spiflash0”
[0003.203] load kernel from storage
[0003.208] decompressor handler not found
[0003.477] Successfully loaded kernel and ramdisk images
[0003.482] board ID = D78, board SKU = 0
[0003.487] sdmmc node status = okay
[0003.490] sdcard instance = 0
[0003.493] sdmmc cd-inverted
[0003.496] sdcard gpio handle 0x5b
[0003.499] sdcard gpio pin 0xc9
[0003.502] sdcard gpio flags 0x0
[0003.505] vmmc-supply 0x9d
[0003.508] cd_gpio_pin = 201
[0003.510] pin_state = 0
[0003.513] Found sdcard
[0003.515] SD-card IS present …
[0003.518] load_and_boot_kernel: SD card detected OK
[0003.524] display_resolution: No display init
[0003.528] Failed to retrieve display resolution
[0003.533] bmp blob is not loaded and initialized
[0003.537] Failed to display boot-logo
[0003.541] NCK carveout not present
[0003.544] Skipping dts_overrides
[0003.547] NCK carveout not present
[0003.557] Find /i2c@7000c000’s alias i2c0
[0003.561] get eeprom at 1-a0, size 256, type 0
[0003.569] Find /i2c@7000c500’s alias i2c2
[0003.573] get eeprom at 3-a0, size 256, type 0
[0003.578] get eeprom at 3-ae, size 256, type 0
[0003.582] pm_ids_update: Updating 1,a0, size 256, type 0
[0003.587] I2C slave not started
[0003.590] I2C write failed
[0003.593] Writing offset failed
[0003.596] eeprom_init: EEPROM read failed
[0003.600] pm_ids_update: eeprom init failed
[0003.604] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.634] pm_ids_update: The pm board id is 3448-0000-400
[0003.641] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0003.649] pm_ids_update: pm id update successful
[0003.654] pm_ids_update: Updating 3,ae, size 256, type 0
[0003.684] pm_ids_update: The pm board id is 3449-0000-400
[0003.690] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0003.698] pm_ids_update: pm id update successful
[0003.728] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.734] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0003.742] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.748] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0003.756] updating /chosen/nvidia,ethernet-mac node 00:04:4b:eb:fc:86
[0003.763] Plugin Manager: Parse ODM data 0x000a4000
[0003.775] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0003.783] Add serial number:1423119032165 as DT property
[0003.792] “bpmp” doesn’t exist, creating
[0003.798] Updated bpmp info to DTB
[0003.803] Updated initrd info to DTB
[0003.806] “proc-board” doesn’t exist, creating
[0003.812] Updated board info to DTB
[0003.815] “pmu-board” doesn’t exist, creating
[0003.821] Updated board info to DTB
[0003.825] “display-board” doesn’t exist, creating
[0003.831] Updated board info to DTB
[0003.834] “reset” doesn’t exist, creating
[0003.839] Updated reset info to DTB
[0003.842] display_console_ioctl: No display init
[0003.847] display_console_ioctl: No display init
[0003.851] display_console_ioctl: No display init
[0003.856] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 la
[0003.890] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0003.896] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fb
[0003.910] Updated bootarg info to DTB
[0003.914] Adding uuid 000000016445b5081400000002050100 to DT
[0003.920] Adding eks info 0 to DT
[0003.925] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0003.931] Updated memory info to DTB
[0003.939] set vdd_core voltage to 1075 mv
[0003.943] setting ‘vdd-core’ regulator to 1075000 micro volts
[0003.949] Found secure-pmc; disable BPMP
U-Boot 2020.04-g4335beb (Feb 19 2022 - 08:56:35 -0800)
SoC: tegra210
Model: NVIDIA Jetson Nano Developer Kit
Board: NVIDIA P3450-0000
DRAM: 4 GiB
[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-8728f3cb)
[0000.147] pmic max77620 NVERC : 0x40
[0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.281] Initialize FailControl
[0000.284] Read PT from (2:0)
[0000.574] Loading NvTbootKernelDTB
[0000.640] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.727] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.921] PT: Partition NCT NOT found !
[0000.929] Next binary entry address: 0x92c00258
[0001.438] Basic modules init took 936048 us
[0001.458] Carveout took -132463 us
[0001.461] CPU initialization took 510780 us
[0001.465] Total time taken by TegraBoot 1417224 us
[0001.470] Starting CPU & Halting co-processor
[0001.685]
[0001.741] platform_init_timer: DONE
[0001.752]
[0001.756]
[0001.826] QSPI bdev is already initialized
[0001.830] Enable APE clock
[0001.833] Un-powergate APE partition
[0001.836] of_register: registering tegra_udc to of_hal
[0001.841] of_register: registering inv20628-driver to of_hal
[0001.847] of_register: registering ads1015-driver to of_hal
[0001.853] of_register: registering lp8557-bl-driver to of_hal
[0001.858] of_register: registering bq2419x_charger to of_hal
[0001.864] of_register: registering bq27441_fuel_gauge to of_hal
[0001.875] gpio framework initialized
[0001.879] of_register: registering tca9539_gpio to of_hal
[0001.884] of_register: registering tca9539_gpio to of_hal
[0001.890] of_register: registering i2c_bus_driver to of_hal
[0001.895] of_register: registering i2c_bus_driver to of_hal
[0001.901] of_register: registering i2c_bus_driver to of_hal
[0001.906] pmic framework initialized
[0001.910] of_register: registering max77620_pmic to of_hal
[0001.915] regulator framework initialized
[0001.919] of_register: registering tps65132_bl_driver to of_hal
[0001.925] initializing target
[0001.931] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.939] board ID = D78, board SKU = 0
[0001.943] Skipping Z3!
[0001.948] fixed regulator driver initialized
[0001.965] initializing OF layer
[0001.968] NCK carveout not present
[0001.972] Skipping dts_overrides
[0001.976] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.992] I2C Bus Init done
[0001.995] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.005] I2C Bus Init done
[0002.008] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.018] I2C Bus Init done
[0002.021] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.031] I2C Bus Init done
[0002.034] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.044] I2C Bus Init done
[0002.047] of_children_init: Ops found for compatible string maxim,max77620
[0002.057] max77620_init using irq 118
[0002.062] register ‘maxim,max77620’ pmic
[0002.066] gpio_driver_register: register ‘max77620-gpio’ driver
[0002.073] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.083] I2C Bus Init done
[0002.087] NCK carveout not present
[0002.096] Find /i2c@7000c000’s alias i2c0
[0002.100] get eeprom at 1-a0, size 256, type 0
[0002.109] Find /i2c@7000c500’s alias i2c2
[0002.112] get eeprom at 3-a0, size 256, type 0
[0002.117] get eeprom at 3-ae, size 256, type 0
[0002.121] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.127] I2C slave not started
[0002.130] I2C write failed
[0002.132] Writing offset failed
[0002.135] eeprom_init: EEPROM read failed
[0002.139] pm_ids_update: eeprom init failed
[0002.143] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.173] pm_ids_update: The pm board id is 3448-0000-400
[0002.180] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.189] pm_ids_update: pm id update successful
[0002.193] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.223] pm_ids_update: The pm board id is 3449-0000-400
[0002.229] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.237] pm_ids_update: pm id update successful
[0002.268] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.274] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.281] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.287] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.296] updating /chosen/nvidia,ethernet-mac node 00:04:4b:eb:fc:86
[0002.302] Plugin Manager: Parse ODM data 0x000a4000
[0002.314] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.329] Find /i2c@7000c000’s alias i2c0
[0002.333] get eeprom at 1-a0, size 256, type 0
[0002.341] Find /i2c@7000c500’s alias i2c2
[0002.345] get eeprom at 3-a0, size 256, type 0
[0002.350] get eeprom at 3-ae, size 256, type 0
[0002.354] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.359] I2C slave not started
[0002.362] I2C write failed
[0002.365] Writing offset failed
[0002.368] eeprom_init: EEPROM read failed
[0002.372] pm_ids_update: eeprom init failed
[0002.376] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.406] pm_ids_update: The pm board id is 3448-0000-400
[0002.412] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.419] pm_ids_update: pm id update successful
[0002.424] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.454] pm_ids_update: The pm board id is 3449-0000-400
[0002.460] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.467] pm_ids_update: pm id update successful
[0002.498] Add serial number:1423119032165 as DT property
[0002.505] Applying platform configs
[0002.512] platform-init is not present. Skipping
[0002.516] calling apps_init()
[0002.522] Couldn’t find GPT header
[0002.527] Proceeding to Cold Boot
[0002.530] starting app android_boot_app
[0002.534] Device state: unlocked
[0002.537] display console init
[0002.545] could not find regulator
[0002.568] hdmi cable not connected
[0002.572] is_hdmi_needed: HDMI not connected, returning false
[0002.577] hdmi is not connected
[0002.580] sor0 is not supportDT entry for leds-pwm not found
e[0002.589] d
[0002.591] display_console_init: no valid display out_type
[0002.599] subnode volume_up is not found !
[0002.602] subnode back is not found !
[0002.606] subnode volume_down is not found !
[0002.610] subnode menu is not found !
[0002.614] Gpio keyboard init success
[0002.694] found decompressor handler: lz4-legacy
[0002.709] decompressing blob (type 1)…
[0002.775] display_resolution: No display init
[0002.779] Failed to retrieve display resolution
[0002.784] Could not load/initialize BMP blob…ignoring
[0002.789] -------> se_aes_verify_sbk_clear: 747
[0002.793] se_aes_verify_sbk_clear: Error
[0002.797] SE operation failed
[0002.800] bl_battery_charging: connected to external power supply
[0002.809] display_console_ioctl: No display init
[0002.814] switch_backlight failed
[0002.820] device_query_partition_size: failed to open partition spiflash0:MSC !
[0002.827] MSC Partition not found
[0002.834] device_query_partition_size: failed to open partition spiflash0:USP !
[0002.841] USP partition read failed!
[0002.844] blob_init: blob-partition USP header read failed
[0002.850] android_boot Unable to update recovery partition
[0002.855] kfs_getpartname: name = LNX
[0002.859] Loading kernel from LNX
[0002.868] Found 19 BFS partitions in “spiflash0”
[0003.189] load kernel from storage
[0003.194] decompressor handler not found
[0003.459] Successfully loaded kernel and ramdisk images
[0003.464] board ID = D78, board SKU = 0
[0003.469] sdmmc node status = okay
[0003.472] sdcard instance = 0
[0003.475] sdmmc cd-inverted
[0003.478] sdcard gpio handle 0x5b
[0003.481] sdcard gpio pin 0xc9
[0003.484] sdcard gpio flags 0x0
[0003.487] vmmc-supply 0x9d
[0003.490] cd_gpio_pin = 201
[0003.492] pin_state = 0
[0003.495] Found sdcard
[0003.497] SD-card IS present …
[0003.500] load_and_boot_kernel: SD card detected OK
[0003.506] display_resolution: No display init
[0003.510] Failed to retrieve display resolution
[0003.515] bmp blob is not loaded and initialized
[0003.519] Failed to display boot-logo
[0003.523] NCK carveout not present
[0003.526] Skipping dts_overrides
[0003.529] NCK carveout not present
[0003.539] Find /i2c@7000c000’s alias i2c0
[0003.543] get eeprom at 1-a0, size 256, type 0
[0003.551] Find /i2c@7000c500’s alias i2c2
[0003.555] get eeprom at 3-a0, size 256, type 0
[0003.560] get eeprom at 3-ae, size 256, type 0
[0003.564] pm_ids_update: Updating 1,a0, size 256, type 0
[0003.569] I2C slave not started
[0003.572] I2C write failed
[0003.575] Writing offset failed
[0003.578] eeprom_init: EEPROM read failed
[0003.582] pm_ids_update: eeprom init failed
[0003.586] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.616] pm_ids_update: The pm board id is 3448-0000-400
[0003.623] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0003.631] pm_ids_update: pm id update successful
[0003.636] pm_ids_update: Updating 3,ae, size 256, type 0
[0003.666] pm_ids_update: The pm board id is 3449-0000-400
[0003.672] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0003.680] pm_ids_update: pm id update successful
[0003.710] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.716] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0003.724] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.730] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0003.738] updating /chosen/nvidia,ethernet-mac node 00:04:4b:eb:fc:86
[0003.745] Plugin Manager: Parse ODM data 0x000a4000
[0003.757] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0003.765] Add serial number:1423119032165 as DT property
[0003.774] “bpmp” doesn’t exist, creating
[0003.780] Updated bpmp info to DTB
[0003.785] Updated initrd info to DTB
[0003.788] “proc-board” doesn’t exist, creating
[0003.794] Updated board info to DTB
[0003.798] “pmu-board” doesn’t exist, creating
[0003.804] Updated board info to DTB
[0003.807] “display-board” doesn’t exist, creating
[0003.813] Updated board info to DTB
[0003.816] “reset” doesn’t exist, creating
[0003.821] Updated reset info to DTB
[0003.824] display_console_ioctl: No display init
[0003.829] display_console_ioctl: No display init
[0003.833] display_console_ioctl: No display init
[0003.838] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 la
[0003.872] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0003.878] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fb
[0003.892] Updated bootarg info to DTB
[0003.896] Adding uuid 000000016445b5081400000002050100 to DT
[0003.902] Adding eks info 0 to DT
[0003.907] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0003.913] Updated memory info to DTB
[0003.921] set vdd_core voltage to 1075 mv
[0003.925] setting ‘vdd-core’ regulator to 1075000 micro volts
[0003.931] Found secure-pmc; disable BPMP
SoC: tegra210
DRAM: 4 GiB
MMC: sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from SPI Flash… SF: Detected mx25u3235f with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
845 bytes read in 31 ms (26.4 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
7159844 bytes read in 335 ms (20.4 MiB/s)
Retrieving file: /boot/Image
34338824 bytes read in 1521 ms (21.5 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_inf
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
ERROR: reserving fdt memory region failed (addr=0 size=0)
Using Device Tree in place at 0000000083100000, end 000000008317ced3
copying carveout for /host1x@50000000/dc@54200000…
copying carveout for /host1x@50000000/dc@54240000…
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (buildbrain@mobile-u64-4415) (gcc version 7.3.1 20180425 [linaro-7.3-2018.1
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 1.082955] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.588680] Host read timeout at address 545c00c4
[ 1.899628] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.907263] imx219 7-0010: board setup failed
[ 1.935734] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.943297] imx219 8-0010: board setup failed
[ 22.015046] cgroup: cgroup2: unknown option “nsdelegate”
[ 23.541992] random: crng init done
[ 23.545398] random: 7 urandom warning(s) missed due to ratelimiting
[ 24.682147] using random self ethernet address
[ 24.686855] using random host ethernet address
[ 26.356415] using random self ethernet address
[ 26.360913] using random host ethernet address
[ 29.674689] IRQ11 no longer affine to CPU2
[ 29.679028] CPU2: shutdown
[ 29.742467] IRQ12 no longer affine to CPU3
[ 29.746992] CPU3: shutdown
[ 50.808334] INFO: rcu_preempt detected stalls on CPUs/tasks:[ 50.809023] CPU0: SError detected, daif=1c0, spsr=02
[ 50.809047] INFO: rcu_sched self-detected stall on CPU
[ 50.809056] 0-…: (1 GPs behind) idle=555/140000000000002/0 softirq=8598/8601 fqs=0
[ 50.809058]
[ 50.809066] rcu_sched kthread starved for 5263 jiffies! g138 c137 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[ 50.845892] 3-O.N: (1 GPs behind) idle=37f/140000000000000/0 softirq=6672/6673 fqs=1
[ 50.845893]
[ 50.845954] rcu_preempt kthread starved for 5264 jiffies! g729 c728 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[ 50.848664] nvgpu: 57000000.gpu nvgpu_init_hal:91 [ERR] no support for 0
