We’re preparing to use Orin with TensorRT8.3 for better performance, but it failed when creating a Builder. Error occurred in myelin which is close-sourced, we’ve gotten stuck here for days and had no clue where to start debugging, so ask for your help:)
Environment
**TensorRT Version tensorrt 8.3:
**GPU Type Orin:
**Nvidia Driver Version 515:
**CUDA Version 11.4:
**CUDNN Version 8.2:
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command.
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
